Hi
I usually create stickers to my instructions with sticker generator.
Does anyone know if there is another piece of software that can generate stickers - preferable at a higher quality than sticker generator?
Thanks
(2018-07-16, 12:15)Johann Eisner Wrote: [ -> ] (2018-07-16, 12:04)Knud Ahrnell Albrechtsen Wrote: [ -> ]Hi
Thanks
Hi
Maybe this will help
https://forums.ldraw.org/thread-22776-po...r#pid28349
Regards Johann
Hi Johann
Thaks for the reply.
I have looked into this program but I couldn't see how I Import a picture and convert it to a .dat file??
Hi again
There is no way to import pictures. You have to draw the pictures yourself. You can set a picture as a background and then you have to draw, draw and draw. ;-)
Regards
(2018-07-16, 17:57)Johann Eisner Wrote: [ -> ]Hi again
Regards
With my drawing skills that will not end up with anything good
Is there no program that has a similar functionality as sticker generator ?
But with a better end result
(2018-07-16, 20:41)Roland Melkert Wrote: [ -> ] (2018-07-16, 20:23)Knud Ahrnell Albrechtsen Wrote: [ -> ]Is there no program that has a similar functionality as sticker generator ?
I'm not sure if you are currently using my sticker generator or the one from Scott, ether way here are both links
http://www.melkert.net/test/stickerGen.html
http://scottwardlaw.com/sticker_generator/
Hi Roland
I am currently using Scotts.
I have tried yours now but it doesn't look like MLCad og LPUB3D supports your program.
(2018-07-17, 4:55)Knud Ahrnell Albrechtsen Wrote: [ -> ]Hi Roland
Textures are a fairly new LDraw feature so not all software supports it (yet).
LPub should support it trough LDView though.
MLCad doesn't support textures as it is not maintained anymore.
Wanted to try Scott's program. But no matter what I do, I always get the error when starting the .ocx file is missing. Although I have already copied them to the system32 folder. :-(
(2018-07-17, 17:49)Johann Eisner Wrote: [ -> ]Wanted to try Scott's program. But no matter what I do, I always get the error when starting the .ocx file is missing. Although I have already copied them to the system32 folder. :-(
If you are running 64-bit Windows, you probably need to copy any ocx files to the SysWOW64 folder instead of the System32 folder. Also, you probably need to run regsvr32 from the command line:
http://www.ctimls.com/Support/KB/How%20T...er_dll.htm
