Full Version: Official Library File Format Restictions
Pages: 1 2 3 4 5 6 7
Stud orientation and mirrored studs are not addressed.
IMHO concerning the part naming when it comes to dimensions, e.g. if it is 2 plates high, it will be .667, this was change in the past from 2/3 to this, I think it should be added and also how many decimals shall there be in the description (3).
Also:
anything Bricklike: Studs x Studs x Bricks
anything Technic looking: Studs x Studs x Studs
Where is the orientation of a part taken care of?
(2020-07-02, 11:34)Willy Tschager Wrote: [ -> ]A constant hassle for newbies is the usage of Metallic vs. Chrome in patterns. May be https://www.ldraw.org/article/512.html#ldconfig is the right place to address that in patterns only Metallic is used to represent shiny colors.
Not just newbies Undecided
(2020-07-02, 11:27)Willy Tschager Wrote: [ -> ]https://www.ldraw.org/article/512.html#colours
where a line is being used for fine detail within a pattern and that pattern is re-used within many parts (and hence sub-parted) in different colours (for example, sub-part s/973p11a.dat)
We do no longer use emphasis lines. Should be deleted.
This has already been deleted in the draft.
(2020-07-02, 11:19)Willy Tschager Wrote: [ -> ]https://www.ldraw.org/article/512.html
Extension
All files in the LDraw Parts Library are required to carry the .DAT extension.
.DAT has to be substituted by .dat. Otherwise the whole discussion will start over again at the next revision.
The draft has been changed. You're still looking at the original.
(2020-07-02, 11:40)Willy Tschager Wrote: [ -> ]I still believe that the list what triggers a HOLD should be added and this:
https://www.ldraw.org/library/tracker/ref/l3pmsg/
should be deleted or updated.
This will be it's own document. I'd like it to be separate from the spec to have be more easily editing.
(2020-07-02, 11:08)Willy Tschager Wrote: [ -> ]is how to deal with blanks in combinations with decimals as in sticker dimensions.
Sticker 3.1 x 3.1 Round
Not sure what you mean. Same rules apply, correct?
(2020-07-02, 11:08)Willy Tschager Wrote: [ -> ]Furthermore this information should be mirrored to https://www.ldraw.org/article/339.html
This article will be cancelled and archived once the draft is ratified.
(2020-07-02, 15:42)Orion Pobursky Wrote: [ -> ]Not sure what you mean. Same rules apply, correct?
Correct. Just showing that nothing change with a decimal.
(2020-07-02, 15:42)Orion Pobursky Wrote: [ -> ]This article will be cancelled and archived once the draft is ratified.
Then the "blank" rule should be mirrored to https://www.ldraw.org/article/512draft.h...icker_desc
(2020-07-02, 14:12)Orion Pobursky Wrote: [ -> ]The draft has been changed. You're still looking at the original.
Sad
(2020-07-02, 13:19)Gerald Lasser Wrote: [ -> ]IMHO concerning the part naming when it comes to dimensions, e.g. if it is 2 plates high, it will be .667, this was change in the past from 2/3 to this, I think it should be added and also how many decimals shall there be in the description (3).
An example has been added to the header spec.
(2020-07-02, 13:19)Gerald Lasser Wrote: [ -> ]Also:
Hmm. Header spec or Official Library spec?
(2020-07-02, 13:19)Gerald Lasser Wrote: [ -> ]Where is the orientation of a part taken care of?
Nowhere. Origin and orientation could be a document in and of itself.
I added some verbiage here:
https://www.ldraw.org/article/512draft.html#origin
I think it's better to write in general terms and let the individual cases be sorted out on the PT but I'm open to rewrite suggestions.
