I'm just going to give a little
bump to the Model Team type 1 rim that I started. It's still a "part I am working on" and I still "anticipate reworking it some", but it may be a while, and if anyone else wanted to have a look over it in the meantime, that would be fine, too.
I uploaded some of them already and now adding finishing touches to the missing ones. THe only one not pictured here is the 65146, the turntable-clip to fasten the strap with the new rounded bricks.
I notices that on all the product pictures the strap is shown with the dents hidden, am I the only one who thinks they should be shown?
The transparent lid of the box shows somehow the need for some surface properties, the window is clear, the sides are rough.
attachment=6143]
(2021-03-02, 23:42)Gerald Lasser Wrote: [ -> ]I am working on the rear mudguard of the Porsche.
If anybody has details on the slope (which I loosely modeled after the 1 x 10 Curved slope) I apprechiate a hi res scan or orthogonal picture!
It is a nice challenge for Pathtruder
Always fun to tweak the start and end shapes.
Ulrich uploaded it already. so I compared both. Amazing similar curvature :-)
What did you use to get it Ulrich? Pathtruder?
attachment=6211]
(2021-03-23, 10:48)Gerald Lasser Wrote: [ -> ]Ulrich uploaded it already. so I compared both. Amazing similar curvature :-)
no ... I have an older student version of Cinema 4D available .... It's fantastic how everything goes from hand to hand.
Via conversion stl or a plugin for complete parts also in all colors (the last mentioned unfortunately ONLY for import).
The mesh control function is more than ingenious ... color-coded ...
for all matters (unfortunately except for lines type 2 and 5)
After converting back to dat ... handwork is the order of the day to bring in our primitives as much as possible.
I took over the longitudinal division of the Z axis from a part of Paul Easter ... Set all points of the Z axis bend to zero
... (certified in the year of the Lord 2013) ....
... the x-axis via the rounding of the hires version of 37352, dat
... our "spaghetti" is simple on the round nose.
Cinema 4D has a dimension function for paths ... so you can simply mark all points and put them on a previously measured diagonal line path ...
More than just desirable to have such a function in LDPE!
a "frame" of polygons created by hand .... the rest can be done with a click on "autofill" ...
something else great for LDPE ..... autofill
BTW:
Please call me Uli ..... Ulrich is only for potential enemies and the tax office .... but well .... that's almost the same ...
And with this wonderful tool, could you easily reduce resolution? I really, really don't like current excessive resolution. And as I said previously it must match 6191...
There's now a little red Corvette on my desk, and I can start working on the new Speed Champions dual moulded wheels.
![[Image: 250x250p.jpg]](https://cdn.rebrickable.com/media/thumbs/parts/elements/6336858.jpg/250x250p.jpg)
(2021-06-04, 19:16)Magnus Forsberg Wrote: [ -> ]There's now a little red Corvette on my desk, and I can start working on the new Speed Champions dual moulded wheels.
Dual Moulded Speed Champion wheels? Did not expect such a thing in this series.
I got one of those Mickey Sets, there are also dual molded wheels in there... Not really a fan of this
It was so close. It doesn't look right. The brake disc looks too small.
attachment=6585]
I'm working on the wings for the LOTR eagle 11467
I have the wings ready, 11777 and 11778, but there seams to be a mix-up between left and right at Bricklink and in LDD.
Brickset have only the design numbers, not the part number.
11777 = is right wing at Bricklink, but is left wing in LDD, but the name in LDD is "Eagle Wing Right". Very confusing.
Anyone have the wings and could check the numbers?
attachment=6618]
Don't forget that the left wing is on the right when you look at the minifig face to face
(and that right hand is the one with the thumb on the left!). More seriously, nothing to offer here...
Working on the new Brick 4 x 4 x 1 Round (Part 79850) which comes with the Harry Potter Stuff.
Part is ready, but needs cleanup in the structure, render looks nice!
attachment=6835]
On the PT!
(2021-12-03, 9:28)Gerald Lasser Wrote: [ -> ]Waiting for a number for those two versatile guys:
My version looks like this.
attachment=7164]
Have you seen any photos of the top side?
(2021-12-03, 22:27)Gerald Lasser Wrote: [ -> ]Here in the review:
https://ramblingbrick.com/2021/12/02/800...iques/amp/
It may not be obvious, but most of the images in the article are 1200x900 resolution, even when they are shown much smaller inline in the article. If you right click on them and open in a new tab, you get a much better look.
I got photos of 42130 parts, so I'll start working on them... But if someone wants to do some parts, feel free - considering the amount of work there's room for many parts authors
. Just post a message here to avoid double work!
(2022-01-03, 9:52)Philippe Hurbain Wrote: [ -> ]I got photos of 42130 parts, so I'll start working on them... But if someone wants to do some parts, feel free - considering the amount of work there's room for many parts authors
I just had all look through some of the new friends sets, they come with plenty of new designs as well... Puh
(2022-07-02, 20:40)Philippe Hurbain Wrote: [ -> ]Far from perfect, but this video shows the set from all angles and is good quality/resolution.
https://youtu.be/HcECpv1UxGw
Good luck 😁
Thanks for the video and the pool has been done!
Now I'm creating the pavement... not so technically challenging except surface stitch but there are hundreds of stones to be painted on every direction.
attachment=8112]
Working on the DB5 windscreen. Partnumber 1874
attachment=8292]
Don't know if this works ....
