2020-06-17, 13:15
(2020-06-16, 11:23)Philippe Hurbain Wrote: [ -> ]Working on Mario plates with rounded corners!Done!
https://www.ldraw.org/cgi-bin/ptscan.cgi...escription
(2020-06-22, 15:22)Willy Tschager Wrote: [ -> ]As this was on my to-do list for many years I would appreciate if you could give us some insight on how you did this AMAZING job.
(2020-06-22, 18:51)Marc Giraudet Wrote: [ -> ]Submissions and projects
(2020-06-22, 18:51)Marc Giraudet Wrote: [ -> ]Submissions and projectsScan enclosed for discussion about colour choice.
(2020-06-22, 18:56)Marc Giraudet Wrote: [ -> ]Scan enclosed for discussion about colour choice.
(2020-06-23, 7:56)Willy Tschager Wrote: [ -> ]OrangeColours used on the part submit was in accordance, excepted walkie-talkie dot. I will uploaded a corrected one as soon as possible.
White
Black
Bluish dark grey
Metallic silver 80
All yellow including the dot on the walkie-talkie 16
(2020-06-23, 7:51)Willy Tschager Wrote: [ -> ]Border 16
Background 15
Cracks 16
Black
Dark Tan
Rust or something
(2020-06-23, 16:42)Orion Pobursky Wrote: [ -> ]I'm not sure about the cracks. They might be printing too.I use pearl gold for the scroll because they are "shinny". In this case a scan don't show the right colour.
I'm pretty sure the scrolls are metallic ink.
I have this part so I check both.
(2020-06-23, 7:51)Willy Tschager Wrote: [ -> ]Rust or something
(2020-06-23, 16:51)Marc Giraudet Wrote: [ -> ]I use pearl gold for the scroll because they are "shinny". In this case a scan don't show the right colour.
Cracks are printed but the colour "light bluish grey" like the part is OK. So 16 is a good choice.
I can use the colour certifiying staff wants.
(2020-06-23, 17:45)Orion Pobursky Wrote: [ -> ]here's my photo:Done in the PT.
I'd use Mettalic_Gold for the scrolls.
Willy's Dark Orange suggestion seem correct for the middle
If the cracks are printed, which they look to be, then they should be Light Bluish Grey, not color 16.
(2020-06-27, 13:42)Philippe Hurbain Wrote: [ -> ](noise of jaw dropping on the floor)...and now that I've seen the part on PT I realize that I need to change the tiling of the floor, it's broken!!!
(2020-06-27, 18:39)Philippe Hurbain Wrote: [ -> ]...and now that I've seen the part on PT I realize that I need to change the tiling of the floor, it's broken!!!Now that is odd. Looks like images ...01 and ...02 haven't uploaded correctly. The exact same problem occurs on both patterned parts, so I don't think this was an error at my end.
There is something weird on PT:
...but I couldn't find anything wrong in your file!
(2020-06-27, 19:39)Orion Pobursky Wrote: [ -> ]I think Willy probably just died. His life's work is complete. ?Nah, I think there's still a set of legs outstanding :-)
(2020-06-27, 18:39)Philippe Hurbain Wrote: [ -> ]...but I couldn't find anything wrong in your file!
Quote:0 !TEXMAP START PLANAR -19.575 -276 148.71___-38.82 -276 144.885___-19.575 -6 148.71 u9328ap0101.png
Quote:0 !TEXMAP START PLANAR -38.82 -276 144.885___-57.405 -276 138.585___-38.82 -6 144.885 u9328ap0102.png
Quote:0 !TEXMAP START PLANAR 106.065 -276 -106.065 119.01 -276 -91.32___106.065 -6 -106.065 u9328ap0130.png
(2020-06-27, 21:11)Magnus Forsberg Wrote: [ -> ]Don't know if it is an error, but the same three lines in both files contain 3 space instead of only 2, in the code.
But why does that matter?
(2020-06-28, 12:15)Philippe Hurbain Wrote: [ -> ]Good luck! Shape is far from trivial...
(2020-06-28, 12:16)Alex Taylor Wrote: [ -> ]But there's a nice LDD mesh available :-)Oops
(2020-06-16, 14:51)Philippe Hurbain Wrote: [ -> ]I thought I posted it already but can't find it again...Done so far:
When I receive the parts, I intend to work on Ducati Panigale tyre, shock absorber and brake disk.
...and also 49736/49737 tubes, and 49577 seaweed/coral
(2020-06-27, 22:08)Alex Taylor Wrote: [ -> ]Indeed! It's an error in the sense that I meant for there to be just two spaces, but presumably there's a bug in the PT's file-parser.
(2020-07-19, 21:40)Alex Taylor Wrote: [ -> ]The geometry for the texture is doing double-duty here; as there is no vector-graphic pattern it seems a bit wasteful to duplicate the geom in a FALLBACK section.
As I said, the three spaces was a typo on my part - I intended to just have the two spaces - but as the spec permits any amount of whitespace between tokens, if the PT is having problems with this then there's a bug there somewhere.
(2020-07-19, 21:45)Orion Pobursky Wrote: [ -> ]Maybe we need to explicitly state that in the Library Spec?
(2020-07-19, 21:46)Orion Pobursky Wrote: [ -> ]Answer: No. the TEXMAP spec requires a FALLBACK section.
(2020-07-20, 0:03)Travis Cobbs Wrote: [ -> ]The FALLBACK section is definitely not intended to be required, and in fact is explicitly stated in the spect to be impossible when using TEXMAP NEXT. If FALLBACK being completely optional is unclear in the TEXMAP spec, then the TEXMAP spec should probably be updated. When no fallback geometry is available, the FALLBACK section should not be present, and the untextured version of the TEXMAP geometry should be used instead. I don't think this is stated as a requirement anywhere, but perhaps it should be.
(2020-07-19, 21:16)Magnus Forsberg Wrote: [ -> ]However, DatHeader goes into a frenzie of error messages about "TEXMAP END before TEXMAP FALLBACK" and "TEXMAP END before surface declared". I guess it's two messages for every line it considers to be an error.
(The same thing happens on 6092p01.dat)
(2020-08-30, 12:58)Takeshi Takahashi Wrote: [ -> ]The colors I've chosen are:
Red: Red (4)
Yellow: Yellow (14)
Brown: Reddish brown (70)
Pink: Pink (13)
Blue: Light blue (9)
(2020-08-30, 13:35)Magnus Forsberg Wrote: [ -> ]Must include the White colour on the top surface, even if it might be a print on white paper/plastic.
Colour 16 must be used if the background is transparent. (note the difference between Background and Backside)
Non of the stickers are placed on a Bright pink or Bright light blue brick, so the choice is up to you.
The background is not supposed to blend in, or disappear.
(2020-07-21, 7:18)Philippe Hurbain Wrote: [ -> ]Working on 42107 Panigale windscreen and 42112 concrete mixer drum...Took a while (side tracked, etc...) but both are now on PT!
(2020-10-03, 10:59)Willy Tschager Wrote: [ -> ]Got the part and will redesign the complete ladder:
https://www.ldraw.org/cgi-bin/ptdetail.c...ts/850.dat
(2020-11-06, 9:42)Gerald Lasser Wrote: [ -> ]Already made the new ECTO Windscreen, waiting for a Design-ID! The bottom is borrowed from the Cylinder Panel, but it is different, missed an Isntagram post that showed the bottom.
