LDCad 1.6 (win+linux) - Printable Version
+--- Thread: LDCad 1.6 (win+linux) (/thread-22200.html)
Pages: 1 2 3 4 5
RE: LDCad 1.6 (win+linux) - Roland Melkert - 2017-07-28
(2017-07-28, 7:38)Willy Tschager Wrote: * I'm experimenting with chains for the first time and love the tool but one of them got totally twisted and I wish there was a button which resets everything back to default.
Resetting templates is something I have been thinking about in relation with switching quality levels, but I never figured out a clean way of doing it. I will try again in 2.0 though.
As for that chain it looks like you added a third skin segment. Chains normally use two alternating (link) skin sections so if you delete the third one (probably the red one?) it goes back to normal.
RE: LDCad 1.6 (win+linux) - Willy Tschager - 2017-07-30
(2017-07-28, 17:19)Roland Melkert Wrote: As for that chain it looks like you added a third skin segment. Chains normally use two alternating (link) skin sections so if you delete the third one (probably the red one?) it goes back to normal.
Correct, but I have no idea who it got there.
Wish of the day:
* I'd like to have a color button or icon which either quick sets the color 47 - Trans clean or makes the selected part even more transparent. I need this for my finetuning technique.
RE: LDCad 1.6 (win+linux) - Owen Dive - 2017-07-30
(2017-07-30, 8:54)Willy Tschager Wrote: Wish of the day:
Oh yeah, being able to temporarily make parts transparent (while not hiding them altogether) would be really useful in certain placement situations, even with part snapping - e.g. making sure that an axle-joiner is sitting precisely on the end of an axle.
Owen.
RE: LDCad 1.6 (win+linux) - Willy Tschager - 2017-08-16
Stupid me. I cannot find the command to refresh the library after I have downloaded some unofficials from the PT and place them in my unofficial folder. Hints are welcome.
RE: LDCad 1.6 (win+linux) - Roland Melkert - 2017-08-16
(2017-08-16, 12:03)Willy Tschager Wrote: Stupid me. I cannot find the command to refresh the library after I have downloaded some unofficials from the PT and place them in my unofficial folder. Hints are welcome.
Library changes should be automatically detected when you start the program.
I know this. But I want to add parts to my library during the build as I come them across, without shutting the prog down.
RE: LDCad 1.6 (win+linux) - Jaco van der Molen - 2017-08-17
(2017-08-16, 17:15)Willy Tschager Wrote:
(2017-08-16, 16:53)Roland Melkert Wrote: Library changes should be automatically detected when you start the program.
I think this is not possible. However, changing any model outside LDCad (in say a texteditor, good ol MLCad, LPub3D), including parts, should trigger a prompt reload.
Adding a part does not do this. I could be wrong though.
RE: LDCad 1.6 (win+linux) - Roland Melkert - 2017-08-17
(2017-08-17, 12:05)Jaco van der Molen Wrote:
(2017-08-16, 17:15)Willy Tschager Wrote: I know this. But I want to add parts to my library during the build as I come them across, without shutting the prog down.
I'm sorry it is indeed not setup to detect/add parts to the library during runtime, it only reloads already known ones upon changes. Any addition to the library needs a restart of the program.
RE: LDCad 1.6 (win+linux) - Roland Melkert - 2017-08-21
I've finally finished rendering the 8852 animation in POV-Ray
https://youtu.be/ZeUtxgQp_7g
It took 30 hours which I let running on the background now and then, hence the two month delay.
