2022-08-28, 10:40
Hey,
this release includes three bugfixes.
One corrects the condlines which are generated by PrimGen2 for all tori types.
The problem: the condline coordinate was calculated in a different way than the coordinate of the quad, which resulted in minor differences.
The other two bugfixes are solving display problems with TEXMAP. I noticed the issues while I was checking 2454aps5.dat.
![[Image: attachment.php?aid=12753]](https://forums.ldraw.org/attachment.php?aid=12753)
Changelog:
(3 bug fixes)
With this release the following critical issues are fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
(3 bug fixes)
- The generated condline coordinates for the Torus from PrimGen2 did not match the coordinates of the generated quads.
- The transparency calculation for TEXMAP images was incorrect on the old OpenGL 2 renderer.
- Fallback geometry in TEXMAP sections was shown (in LDraw Standard render mode with the old OpenGL 2 renderer).
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.62.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.62-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.62.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
