Full Version: Parts we are Working on - Part Deux
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
(2020-05-27, 10:13)Magnus Forsberg Wrote: [ -> ]No, that is the number of the design/pattern. Not the shape of the part.
Thank you for mention this. I just forget it could not be the number of shape of the part. But then, I was looking for some data at Brickset and I found lego IDs of lots of printed parts are different from their IDs of shape of the parts except body part. i.e. 76382 of upper body.
Getting along well!
[attachment=5317]
(2020-05-28, 20:10)Gerald Lasser Wrote: [ -> ]Getting along well!
Banana.
Big Grin Big Grin  Nice!
Working on Mario plates with rounded corners!
I thought I posted it already but can't find it again...
When I receive the parts, I intend to work on Ducati Panigale tyre, shock absorber and brake disk.
...and also 49736/49737 tubes, and 49577 seaweed/coral
(2020-06-16, 14:51)Philippe Hurbain Wrote: [ -> ]I thought I posted it already but can't find it again...
The disc brake is already done:
https://www.ldraw.org/cgi-bin/ptdetail.cgi?s=64516
(2020-06-16, 15:19)Magnus Forsberg Wrote: [ -> ]The disc brake is already done:
Oh thanks, Magnus, I missed it (confused with the other disk brake).
I have got the shock-absorber as well, already disassembled.
Unfortunately I did not find a way to remove the top (LBG) axle-holder without damaging it. So I cautiously cut it away :-) I can finish this one if you do not want to break yours :-)
The 65143 is nearly done, I can upload it
For the seaweed I have a draft done, I can share if you want.
The Ducati tyres look very similar to the existing ones (not working on them). The main difference is that the tread is a bit rounder than the first edition
[Image: 50013291176_03a221077e_c.jpg]New Lego Shockabsorber by 1wave, on Flickr
[Image: 50013553877_e5db6193e0_c.jpg]New Lego Shockabsorber by 1wave, on Flickr
(2020-06-16, 17:13)Gerald Lasser Wrote: [ -> ]I have got the shock-absorber as well, already disassembled.
I am fine with it if you complete the shock absorber! Or I can step in and make the subparts that you don't want to do - as you want!
Quote:For the seaweed I have a draft done, I can share if you want.
Yes please!
