Full Version: Parts we are Working on - Part Deux
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Working on the sticker sheet 4603014 in set 3061 (City Park Cafe, Friends 2012), based on the image at Bricklink
https://www.bricklink.com/v2/catalog/cat...=0#T=C&C=0
If a better resolution image can be provided, it will be highly appreciated.
The colors I've chosen are:
Red: Red (4)
Yellow: Yellow (14)
Brown: Reddish brown (70)
Pink: Pink (13)
Blue: Light blue (9)
But, are Bright pink (29) and Bright light blue (212) more appropriate,
according to the set inventory?
(2020-08-30, 12:58)Takeshi Takahashi Wrote: [ -> ]The colors I've chosen are:
Red: Red (4)
Yellow: Yellow (14)
Pink: Pink (13)
Must include the White colour on the top surface, even if it might be a print on white paper/plastic.
Colour 16 must be used if the background is transparent. (note the difference between Background and Backside)
Non of the stickers are placed on a Bright pink or Bright light blue brick, so the choice is up to you.
The background is not supposed to blend in, or disappear.
(2020-08-30, 13:35)Magnus Forsberg Wrote: [ -> ]Must include the White colour on the top surface, even if it might be a print on white paper/plastic.
Thank you for your advice.
I'll continue with making remaining stickers, including non-rectangular two pieces.
Got the part and will redesign the complete ladder:
[Image: 850.png]
https://www.ldraw.org/cgi-bin/ptdetail.c...ts/850.dat
(2020-07-21, 7:18)Philippe Hurbain Wrote: [ -> ]Working on 42107 Panigale windscreen and 42112 concrete mixer drum...
Took a while (side tracked, etc...) but both are now on PT!
https://www.ldraw.org/cgi-bin/ptdetail.c...p01c01.dat
https://www.ldraw.org/cgi-bin/ptdetail.c...421p01.dat
I'll be working on 3039p14.dat, which is an older patterned slope used in several 90s-era town sets (aka my Dark Ages). The pattern can be obtained from vectors in the official instructions PDF.
EDIT: Now on PT.
[attachment=5810]
https://www.ldraw.org/cgi-bin/ptdetail.c...039p14.dat
I'm also doing sticker sheet 170903, which will involve 3 new sticker parts from extant patterns. One of the stickers seems to already exist as 170872a. I will also need to refresh myself on how best to do a formed sticker…
Still on my back burner is Model Team rim 32004a. I've done a first draft, but I'm not fully sold on the results yet. Opinions are welcome. :-)
Already made the new ECTO Windscreen, waiting for a Design-ID! The bottom is borrowed from the Cylinder Panel, but it is different, missed an Isntagram post that showed the bottom.
[attachment=5855]
(2020-11-06, 9:42)Gerald Lasser Wrote: [ -> ]Already made the new ECTO Windscreen, waiting for a Design-ID! The bottom is borrowed from the Cylinder Panel, but it is different, missed an Isntagram post that showed the bottom.
Many thanks.
Bruno Altmann
I'm working on the orange torso from the set 60222.
Does anybody have the scan?
This is what I have done so far:
https://drive.google.com/file/d/1utPbQr5...sp=sharing
