2019-04-10, 5:03
2019-04-10, 5:05
I am currently working all 6 (yes 6) variations of the model
2019-04-12, 22:02
(2019-04-10, 5:05)Orion Pobursky Wrote: [ -> ]I am currently working all 6 (yes 6) variations of the model
The base model for Gull Wing and Convertible is done. This model would have been far more of a pain were it not for LDCad part snapping and flex objects.
[attachment=3524]
2019-04-19, 4:26
[attachment=3538]
8448 - Super Street Sensation - Convertible
OMR Compliant
Missing: Stickers
Notes:
- The double compound u-joint in the steering link needs work.
- The flexible elements make the model file very large (20 MB) so it is zipped.
OMR Compliant
Missing: Stickers
Notes:
2019-04-19, 16:43
I did this animation a couple of years ago. Unfortunately I can't remember the credentials for my old YT account.
Model was done in MLCad. All angles were calculated by hand or by using AutoCad.
2019-04-24, 3:51
[attachment=3549]
8448 - Super Street Sensation - Wing Doors
OMR Compliant
Missing: Stickers
Notes:
- Same comments as the Convertible
OMR Compliant
Missing: Stickers
Notes:
2019-04-24, 3:54
(2019-04-19, 4:26)Orion Pobursky Wrote: [ -> ]8448 - Super Street Sensation - Convertible
OMR Compliant
Missing: Stickers
Notes:
I made some minor adjustments to the windshield based on errors found while the Wing Door model. Zip file updated.
2019-04-26, 3:52
[attachment=3557]
8448 - Super Street Sensation - Concept Car
OMR Compliant
Missing: Stickers
Notes:
OMR Compliant
Missing: Stickers
Notes:
2019-04-28, 19:39
(2019-04-26, 3:52)Orion Pobursky Wrote: [ -> ]8448 - Super Street Sensation - Concept Car
OMR Compliant
Missing: Stickers
Notes:
Stupid question: Which is the main model?
2019-04-28, 20:30
(2019-04-28, 19:39)Johann Eisner Wrote: [ -> ]Stupid question: Which is the main model?
The convertible. I’m posting in the order they appear in the BIs. Racer’s almost done and there are 2 more after that. I also plan on posting a convertible top down and wing doors down versions
2019-04-28, 20:43
(2019-04-28, 20:30)Orion Pobursky Wrote: [ -> ]The convertible. I’m posting in the order they appear in the BIs. Racer’s almost done and there are 2 more after that. I also plan on posting a convertible top down and wing doors down versions
Thx.
Main Model is in the OMR. --> http://omr.ldraw.org/file/1166
2019-04-29, 5:16
(2019-04-28, 20:43)Johann Eisner Wrote: [ -> ]Thx.
Hold off on the Concept car and Racer. I spotted an error I need to fix.
2019-04-29, 5:17
[attachment=3587]
8448 - Super Street Sensation - Racer
OMR Compliant
Missing: Stickers
Notes:
OMR Compliant
Missing: Stickers
Notes:
2019-05-01, 2:50
(2019-04-29, 5:16)Orion Pobursky Wrote: [ -> ]Hold off on the Concept car and Racer. I spotted an error I need to fix.
The error has been fixed and the files updated.
2019-05-01, 3:39
[attachment=3603]
8448 - Super Street Sensation - Hot Rod
OMR Compliant
Missing: Stickers
Notes:
OMR Compliant
Missing: Stickers
Notes:
2019-05-01, 14:26
(2019-05-01, 3:39)Orion Pobursky Wrote: [ -> ]8448 - Super Street Sensation - Hot Rod
OMR Compliant
Missing: Stickers
Notes:
Confratulation Orión, grate job. I think this may take tons of hous to finish it?
2019-05-01, 14:43
(2019-05-01, 14:26)tatubias Wrote: [ -> ]Confratulation Orión, grate job. I think this may take tons of hous to finish it?
One more alternate model to do: Buggy. This really didn't take as long as I thought it would. Example: I did the Hot Rod over the course of a few hours yesterday. The modularity of this set and the features of LDCad has made the process way easier than it used to be.
2019-05-01, 15:30
(2019-05-01, 3:39)Orion Pobursky Wrote: [ -> ]8448 - Super Street Sensation - Hot RodVery nice indeed! But you should embed unofficial parts: I'm missing ldcFlexAxleCap...
OMR Compliant
Missing: Stickers
Notes:
2019-05-01, 15:51
(2019-05-01, 15:30)Philippe Hurbain Wrote: [ -> ]Very nice indeed! But you should embed unofficial parts: I'm missing ldcFlexAxleCap...
Ugh. I thought I fixed that problem. I'll update tonight.
2019-05-02, 3:35
(2019-05-01, 15:51)Orion Pobursky Wrote: [ -> ]Ugh. I thought I fixed that problem. I'll update tonight.
Should be fixed now. File updated.
2019-05-02, 12:00
(2019-05-02, 3:35)Orion Pobursky Wrote: [ -> ]Should be fixed now. File updated.Maybe a cache issue, but it seems that there is no ldcFlexAxleCap.dat embedded
2019-05-02, 18:15
(2019-05-02, 12:00)Philippe Hurbain Wrote: [ -> ]Maybe a cache issue, but it seems that there is no ldcFlexAxleCap.dat embedded
I just downloaded the model onto my work computer and checked. The path caps are inlined in the flex part so there must be some aggressive caching going on with your browser. There might also be an issue with LDCad not finding the file since the META references it. I'll attach it to this post.
2019-05-02, 18:29
The buggy is giving me fits. I might take a break and work on something else for a bit.
2019-05-02, 18:34
(2019-05-02, 18:15)Orion Pobursky Wrote: [ -> ]I just downloaded the model onto my work computer and checked. The path caps are inlined in the flex part so there must be some aggressive caching going on with your browser. There might also be an issue with LDCad not finding the file since the META references it. I'll attach it to this post.My bad (to some extent...): only LDCad complains about missing ldcFlexAxleCap. But if you embed it along with all unofficial files, it solves all issues (in LDCad, file -> cleanup -> check "embed unofficial parts")
2019-05-02, 19:00
(2019-05-02, 18:34)Philippe Hurbain Wrote: [ -> ]My bad (to some extent...): only LDCad complains about missing ldcFlexAxleCap. But if you embed it along with all unofficial files, it solves all issues (in LDCad, file -> cleanup -> check "embed unofficial parts")
This donor part will be part of the next LDCad release so I think I'll just leave it out. I don't want to make it OMR conformed.
2019-05-04, 17:53
The part is here:
https://forums.ldraw.org/thread-23380-po...l#pid31732
As Orion wrote it will be part of 1.6c
