Full Version: 1970's - LEGOland and hobby sets
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
You might have a look on what I did on 364:
http://omr.ldraw.org/files/1450
Thanks very much for improving the model!
I've written the !HISTORY line for update log.
[attachment=6457]
[attachment=6459]
[attachment=6460]
Set: 1589 - Main Street
OMR Compliant: Yes
Known errors: Missing stickers, flexible rope
Done with: MLCad 3.51
As the flexible rope for crane has an important role for this set, I'd like to add it referring Willy and Jeremie's works.
[attachment=6461]
[attachment=6462]
Set: 1620-2 - Chocolate Factory
OMR Compliant: Yes
Known errors: Flexible rope
[EDIT 2021-07-26] Added missing stickers, corrected minifig position (Thanks Jeremie for review)
Hi Takeshi,
Nice sets of that era! Will be perfect with your corresponding stickers when they become official parts Smile
I fixed a small glitch in 1589, at the back of the office ground floor (one 3665a and one 3660 were misplaced, and one 3005 had become a 3004; plus corrected the building steps).
Here's the fixed file:
[attachment=6469]
Another point I noticed is the alternation of the transparent 3010's / 3622's on the right part of the bus stop. The instructions scans available on the net are not optimal, but apparently they should be in the 3010/3622 and 3622/3010 order alternately (which seems confirmed by the photo overviews of the set). I didn't change that though, not sure of what you'll decide
[attachment=6489]
[attachment=6490]
Known errors: None
Done with: LDCad 1.6d
Hint: Stickers are at the PT ready to be reviewed
Nice model, as always with you Willy Smile
It's only recently, and thanks to LDraw, that I discovered this first version of the Minifigs.
On this one I find it particularly cute the way scarves are represented !
Hello,
Here is sets 648 and 690.
I personnaly had the 690 during my childhood. Ldraw made me discover its ancestor the 648 Smile
[attachment=6493]
[attachment=6491]
[attachment=6494]
[attachment=6492]
Thanks to Takeshi for the recently added parts - u454 slanted signpost and 1955 Shell Logo !
For the 690 I had to create the 8x22 baseplate (inlined), which from what I understood only existed for this specific set. I named it u568 (it was previously referenced as x568), is this correct ?
Files are OMR compliant, except for the fact they use the three unofficial parts below, currently in ACCN state on the Part Tracker:
  • u454p01.dat
  • u454p02.dat
  • 3004pt8.dat
Thanks for making nice use of part u454!
I recommend you to submit u568 into parts tracker.
It's a nice part.
(2021-05-18, 14:17)Takeshi Takahashi Wrote: [ -> ]I recommend you to submit u568 into parts tracker.
It's a nice part.
Yes, go for it!
