2020-11-14, 15:19
2020-11-15, 12:44
Set: 670-1 Mobile Crane
OMR Compliant: Yes
Known errors: Missing stickers (Danger stripes on vehicle body), Missing flexible string
Inlined unofficials: 004656a (on PT, admin certified)
Done with: MLCad 3.51
This model is built several years ago and cleaned up just now.
Of course creating flexible items and any other improvements are welcomed.
[attachment=5886]
[attachment=5887]
OMR Compliant: Yes
[attachment=5886]
[attachment=5887]
2020-11-15, 15:09
Set: 643-1 Flatbed Truck
OMR Compliant: Yes
Known errors: none
[attachment=5888]
[attachment=5889]
OMR Compliant: Yes
Known errors: none
[attachment=5888]
[attachment=5889]
2020-11-16, 15:19
Set: 644-2 Police Mobile Patrol
OMR Compliant: Yes
Known errors: none
[attachment=5894]
[attachment=5895]
OMR Compliant: Yes
Known errors: none
[attachment=5894]
[attachment=5895]
2020-11-20, 13:42
Set: 671-1 Shell Petrol Tanker
OMR Compliant: Currently no (not inlined unofficial stickers)
Known errors: none
[attachment=5898]
[attachment=5899]
Updated with creating stickers and flexible rope.
Known errors: none
[attachment=5898]
[attachment=5899]
2020-11-20, 19:20
(2020-11-15, 12:44)Takeshi Takahashi Wrote: [ -> ]Set: 670-1 Mobile Crane
OMR Compliant: Yes
Indeed, ropes and strings are critical to many of the models from this era. Perhaps none less so than this one. :-)
LDCad can handle them of course, but they are fiddly and take a long time to build, at least if you're going for a great deal of accuracy. I've been working at things like pre-made knots and spools, etc., but I find that these differ almost with each different model. Wish there were a better way to automate them!
2020-11-22, 7:57
(2020-11-20, 19:20)N. W. Perry Wrote: [ -> ]Indeed, ropes and strings are critical to many of the models from this era. Perhaps none less so than this one. :-)
I agree that the flexible ropes and hoses have very important roles in these models.
I'm now learning the use of LDCad including building flexible parts, to migrate from MLCad getting out-of-date.
The knots and spools are so difficult for me currently (authoring patterned tiles or bricks is far easier than them!!),
but I'll try to create them beginning from an update for set 377.
2020-11-22, 8:24
(2020-11-20, 13:42)Takeshi Takahashi Wrote: [ -> ]Known errors: Missing flexible hose (rope)
Check out:
http://omr.ldraw.org/files/1210
http://omr.ldraw.org/files/1450
Done with LDCad or Synth
2020-11-22, 21:56
(2020-11-22, 7:57)Takeshi Takahashi Wrote: [ -> ]I agree that the flexible ropes and hoses have very important roles in these models.
You can create cap parts for things like common knots (if you don't want to model the knot itself, a sphere primitive can be a good approximation), and you could do the same with a single spool loop (or even a whole course of them, if you need a full spool). But I think it would be cool to have an automated spooling script, similar to how spring part meshes are generated.
2020-12-31, 13:09
(2020-04-23, 19:54)Orion Pobursky Wrote: [ -> ]LDCad is far superior for this.
Updated, with creating flexible hose by LSynth (Missing invisible knots).
I wonder how to make the hose thicker as a real part.
[attachment=5989]
[attachment=5990]
2020-12-31, 16:03
(2020-12-31, 13:09)Takeshi Takahashi Wrote: [ -> ]Updated, with creating flexible hose by LSynth (Missing invisible knots).
I use the LSynth LS60 segment in my own LDCad string template (it looks more like real string than the cylindrical donors that come with LDCad). You can easily scale them in X and Z to make the string thicker or thinner, by changing the rotation matrix in the path skin dialog.
2021-01-05, 13:48
Set: 672-1 Fire Engine and Trailer
OMR Compliant: Yes
I'll create the missing flexible hose rope...but unfortunately it will be invisible
[attachment=6008]
[attachment=6009]
OMR Compliant: Yes
[attachment=6008]
[attachment=6009]
2021-01-05, 13:49
Set: 673-1 Rally Car and Motorbike
OMR Compliant: Currently no (unofficial stickers not inlined)
Known errors: none
[attachment=6012]
[attachment=6013]
Updated with stickers!
Known errors: none
[attachment=6012]
[attachment=6013]
2021-01-10, 7:31
I've created the missing signboard u454p01 and hose (copied from set 377).
This is a fit check (not OMR conform), and I'll inline them after the part is certified.
[attachment=6028]
[attachment=6029]
Edit 2022-03-20: Made OMR compliant (part u454p01 got official, and inlined LS60)
[attachment=6028]
[attachment=6029]
2021-01-17, 10:31
Set: 621-2 - Shell Tanker Truck
OMR Compliant: Yes
Known errors: Substituted parts (3004p60 - "Brick 1 x 2 with Shell Logo I Pattern" instead of 3004px17 - "Brick 1 x 2 with Shell Logo II Pattern")
Done with: Studio 2.1.12(1) and MLCad 3.50
Notes: Wrong original instructions: there are three Bricks with the Shell logo, not two!
(Updated "Known errors")
[attachment=6031]
[attachment=6032]
OMR Compliant: Yes
[attachment=6031]
[attachment=6032]
2021-03-09, 13:20
Set: 344-1 Bungalow
OMR Compliant: Yes
Known errors: Substituted part: Tree 3471 instead of FTPineH(upn0401)
In real world, removal of old tile 3068a must be some nightmare...
OMR Compliant: Yes
2021-03-27, 14:13
Set: 674-1 Forklift and Truck
OMR Compliant: Yes
Known errors: Missing forklift spring
[attachment=6224]
[attachment=6225]
OMR Compliant: Yes
[attachment=6224]
[attachment=6225]
2021-03-27, 19:29
Missing the spring.
2021-03-28, 13:39
(2021-03-27, 19:29)Willy Tschager Wrote: [ -> ]Missing the spring.
Thanks, but I couldn't find no appropriate springs in official library or PT.
2021-03-28, 14:31
(2021-03-27, 19:29)Willy Tschager Wrote: [ -> ]Missing the spring.Making a spring is not a very big issue (could probably be derived from https://www.ldraw.org/cgi-bin/ptdetail.c...181c01.dat), but where is it supposed to attach to the forklift parts???
2021-03-28, 15:25
(2021-03-28, 14:31)Philippe Hurbain Wrote: [ -> ]Making a spring is not a very big issue (could probably be derived from https://www.ldraw.org/cgi-bin/ptdetail.c...181c01.dat), but where is it supposed to attach to the forklift parts???
Do you know the correct number of that spring? Could it be the same?
2021-03-28, 17:02
(2021-03-28, 15:25)Magnus Forsberg Wrote: [ -> ]Do you know the correct number of that spring? Could it be the same?The true question is - is there a spring??? Mechanism could simply rely on friction between 3430 and 3431... I see none on all photos I checked!
2021-03-28, 17:11
Yes, it has.
I remember having one as a kid and it was a lot of fun shooting stuff in the air with the fork.
And the parts have hooks for a spring.
2021-03-28, 17:44
(2021-03-28, 17:11)Magnus Forsberg Wrote: [ -> ]Yes, it has.Yes... https://www.bricklink.com/v2/catalog/cat...2#T=C&C=22
I remember having one as a kid and it was a lot of fun shooting stuff in the air with the fork.![]()
And advice in 3430 and so called "3429": 0 // Needs work: Spring attachment
I said so called because imho it's actually 3431!
2021-03-28, 20:31
It's definitely not the same spring.
70181 is from 1983 (for the newer, larger 73367 FORK-LIFT TRUCK), while 74603 FORK-LIFT TRUCK (the one being shown here) dates as far back as 1972.
Plus, I did some measurements for Philo at his request.
The older spring is actually of a larger diameter, and is shorter.
In addition to the spring, there are connection points missing from the platform and the standard for the spring to attach to. I gave Philo some reference photos and suggestions (one could "cheat" and just use a cylinder at the top, even though the shape is more like a box with the top two edges rounded off. The peg on the platform is a lot more involved, if one wants to sweat the details.)
2021-03-28, 20:34
(2021-03-28, 17:44)Philippe Hurbain Wrote: [ -> ]Yes... https://www.bricklink.com/v2/catalog/cat...2#T=C&C=22
Philo is right, this is one of the oldest misnumberings in LDRAW.
3429 is unknown, but definitely not the FORK-LIFT PLATFORM, it should be 3431. (3430 is correct as the FORK-LIFT STANDARD)
Note: 3429 is also definitely not the spring; which would have a 6xxx or 7xxxx numbering, owing to the fact that it is metal.
2021-04-04, 13:44
Finally completed this set!!
Set: 374-1 Fire Station
OMR Compliant: Currently no (Unofficial stickers not inlined)
Known errors: none
Known errors: none
2021-04-14, 10:43
[attachment=6313]
[attachment=6314]
Known errors: None
Done with: LDCad 1.6d
Note: A set I wanted badly as a kid but newer got - now I have and in perfect shape. Love being an AFoL.
Hint: Stickers are at the PT ready to be reviewed
[attachment=6314]
Known errors: None
2021-05-07, 18:12
Hello Takeshi,
Here is the string I made for this nice 670 set. I think it's not too bad... Hope you'll like it
[attachment=6454]
[attachment=6453]
Made with LDCad the instructions found on JC Tchang's site about how to make a string with the LS60 LSynth part (inlined in the mpd). And quite some time playing with Bezier curves while taking a real-world knot as a reference...
You'll see I fixed three minor glitches, too:
- two 3020's were inverted among building steps
- the crane was vertically overlapping the truck by 8 LDUs
- the red block was lower than (invisible) ground
Finally I couldn't resist but put the stickers... but of course, thanks must go to yourself for having created two of those (BTW I'm impressed by the large numbers of stickers you submitted recently on the PT, great work !)
[attachment=6454]
[attachment=6453]
2021-05-08, 7:02
Great collaborative work on this one
I'm especially fond of rope knot!
2021-05-08, 8:38
2021-05-08, 13:20
Thanks very much for improving the model!
I've written the !HISTORY line for update log.
[attachment=6457]
[attachment=6457]
2021-05-09, 4:33
[attachment=6459]
[attachment=6460]
Set: 1589 - Main Street
OMR Compliant: Yes
Known errors: Missing stickers, flexible rope
As the flexible rope for crane has an important role for this set, I'd like to add it referring Willy and Jeremie's works.
[attachment=6460]
OMR Compliant: Yes
2021-05-10, 15:28
[attachment=6461]
[attachment=6462]
Set: 1620-2 - Chocolate Factory
OMR Compliant: Yes
Known errors: Flexible rope
[EDIT 2021-07-26] Added missing stickers, corrected minifig position (Thanks Jeremie for review)
[attachment=6462]
OMR Compliant: Yes
2021-05-12, 19:22
Hi Takeshi,
Nice sets of that era! Will be perfect with your corresponding stickers when they become official parts
I fixed a small glitch in 1589, at the back of the office ground floor (one 3665a and one 3660 were misplaced, and one 3005 had become a 3004; plus corrected the building steps).
Here's the fixed file:
[attachment=6469]
Another point I noticed is the alternation of the transparent 3010's / 3622's on the right part of the bus stop. The instructions scans available on the net are not optimal, but apparently they should be in the 3010/3622 and 3622/3010 order alternately (which seems confirmed by the photo overviews of the set). I didn't change that though, not sure of what you'll decide
[attachment=6469]
2021-05-15, 20:30
[attachment=6489]
[attachment=6490]
Known errors: None
[attachment=6490]
Known errors: None
2021-05-16, 11:19
Nice model, as always with you Willy
It's only recently, and thanks to LDraw, that I discovered this first version of the Minifigs.
On this one I find it particularly cute the way scarves are represented !
2021-05-16, 11:27
Hello,
Here is sets 648 and 690.
I personnaly had the 690 during my childhood. Ldraw made me discover its ancestor the 648
[attachment=6493]
[attachment=6491]
[attachment=6494]
[attachment=6492]
Thanks to Takeshi for the recently added parts - u454 slanted signpost and 1955 Shell Logo !
For the 690 I had to create the 8x22 baseplate (inlined), which from what I understood only existed for this specific set. I named it u568 (it was previously referenced as x568), is this correct ?
Files are OMR compliant, except for the fact they use the three unofficial parts below, currently in ACCN state on the Part Tracker:
[attachment=6493]
[attachment=6491]
[attachment=6494]
[attachment=6492]
- u454p01.dat
- u454p02.dat
- 3004pt8.dat
2021-05-18, 14:17
Thanks for making nice use of part u454!
I recommend you to submit u568 into parts tracker.
It's a nice part.
It's a nice part.
2021-05-18, 15:33
(2021-05-18, 14:17)Takeshi Takahashi Wrote: [ -> ]I recommend you to submit u568 into parts tracker.Yes, go for it!
It's a nice part.
2021-05-23, 14:30
[attachment=6517]
[attachment=6518]
Set: 379-1 - Bus Station
Known errors: none
[EDIT 2021-07-07] Fixed window snap error, thanks Jeremie for review
[attachment=6518]
Known errors: none
2021-05-24, 16:25
[attachment=6520]
[attachment=6521]
Set: 381-2 - Police Headquarters
OMR Compliant: Yes
Known errors: none
[EDIT 2021-07-07] Fixed misplaced spout, thanks Jeremie for review
[attachment=6521]
OMR Compliant: Yes
Known errors: none
2021-05-24, 18:23
(2021-05-24, 16:25)Takeshi Takahashi Wrote: [ -> ]Set: 381-2 - Police Headquarters
Never had this set as I was knee deep into Classic Space and there were just Christmas and birthday.
2021-05-24, 19:10
Part u568 submitted today on the parts tracker !
2021-05-25, 16:29
(2021-05-24, 18:23)Willy Tschager Wrote: [ -> ]Never had this set as I was knee deep into Classic Space and there were just Christmas and birthday.
Yes, classic space sets are also very nice and I like them.
This set 381 was released before I was born (in 1983) and my first police station set is 6386, so I've built this first time on LDraw!
I think this set is very well-designed for action playing with minifigs, and broad possibility for alternative builds (no STAMPs used).
2021-05-25, 16:31
[attachment=6529]
[attachment=6530]
Set: 607-1 - Mini Loader
OMR Compliant: Yes
Known errors: none
[attachment=6530]
OMR Compliant: Yes
Known errors: none
2021-05-25, 16:31
[attachment=6531]
[attachment=6532]
Set: 608-2 - Taxi
OMR Compliant: Yes
Known errors: none
[attachment=6532]
Set: 608-2 - Taxi
OMR Compliant: Yes
Known errors: none
2021-05-26, 12:15
[attachment=6538]
[attachment=6539]
Set: 645-1 - Police Helicopter
OMR Compliant: Yes
Known errors: none
[attachment=6539]
OMR Compliant: Yes
Known errors: none
2021-05-27, 13:44
[attachment=6540]
[attachment=6541]
Set: 646-1 - Auto Service
OMR Compliant: Yes
Known errors: none
[attachment=6541]
OMR Compliant: Yes
Known errors: none
2021-05-27, 21:00
All these sets are really cool, especially when decorated with their dedicated stickers
I noticed a few glitches here and there - nothing very important but I think would be better if they're fixed
- sets 640-2 and 374-1: the Minifig airtank (3838.dat) should be 2 LDU lower
- set 379-1 : the 3853 (windows frames) and 3855b (windows glasses) aren't correctly snapped together, on all 7 occurences
- set 381-2 : the 3496c01 spout overlaps the 3660 underneath by 8 LDUs
- set 646: according to the instructions, the 3829c01 steering wheel should be yellow
- If I believe rebrickable.com as well as the instructions visuals, many of these sets have 3062a's (with solid stud) rather than 3062b's (with hollow stud); apparently the latter wasn't produced before 1978 anyway. This is particularly noticeable on the main picture of instructions for set 672-1, for example.
- On two sets (372 and 1620), some Minifig are standing in the gap between two pairs of studs (and are overlapping them). Not sure whether this was intended or not (especially for 372 where this permits the Minifig to be in the center of the watchtower) ?
