Good evening everybody,
I have this file and i want to open it in ldview, it opens but it also give several errors.
anyone idea how to solve these errors ?
Hi jkorten.
Looks like you have a file converted from LDD
59510 is the Battery box 919.dat, but with two lid, 918.dat. We don't seem to have a shortcut for that combination.
59165 is the Button on that Battery box, 920.dat
A complete Battery box is present as 58119.dat
59158 is the output axle on XL Motor 58121, called 47157.dat
or
59158 is the output axle on Motor 99455, called 99543.dat
attachment=2969]
Open your file in a text editor and replace accordingly.
Thanks for the help, i can now open it in ldview without errors.
But now i want to open it in ldpub3d to make a good manual, but it does not work.
Anyone, any idea ?
File it attached
(2017-12-12, 21:31)jkorten Wrote: [ -> ]Thanks for the help, i can now open it in ldview without errors.
Anyone, any idea ?
File it attached
What problem are you having? I downloaded your file and opened it in LPub3D with no problems.
Kevin
(2017-12-25, 23:57)Kevin Wrote: [ -> ] (2017-12-12, 21:31)jkorten Wrote: [ -> ]Thanks for the help, i can now open it in ldview without errors.
Anyone, any idea ?
File it attached
Kevin
I rechecked the lpub3d software version and i was using the 19 version so i downloaded the 20 version, but it still is nto working.
When i open the file it will only come up the the attached screen.
Ah! your problme is simple: there is no building steps in your model so your building instructions just adds all parts (btw, THAT's a behemoth of a model!) at the first page. To create good building instructions, you have to break the model into smaller submodels and add building steps to make them buildable. That's a huge task, especially for a large model like this one that makes my editor (LDCad) crawl...
In order to help a bit, I added steps every ten parts in your model (using MLCad autostep function), resulting in a 650+ steps model. Won't be very usable, but at least you'll see what it looks like!
(2017-12-26, 9:04)Philippe Hurbain Wrote: [ -> ]Ah! your problme is simple: there is no building steps in your model so your building instructions just adds all parts (btw, THAT's a behemoth of a model!) at the first page. To create good building instructions, you have to break the model into smaller submodels and add building steps to make them buildable. That's a huge task, especially for a large model like this one that makes my editor (LDCad) crawl...
Good morning,
Thanks for the reply. I will start learning how to work with MLCad.
Can you help me a bit with pointing out where to find this autostep function in MLCad, and what do i have to use to break the submodels up in to more steps ?
Thanks in advance!
