TXT2DAT integrated in LDPC 1.7.7 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: Parts Author Tools (https://forums.ldraw.org/forum-24.html) +--- Thread: TXT2DAT integrated in LDPC 1.7.7 (/thread-29064.html) |
TXT2DAT integrated in LDPC 1.7.7 - Gabriel Läufer - 2025-09-10 Hi everyone, Hi Nils, To accelerate the sticker and pattern generation process, I’ve got some exciting news for you! No idea how many of you are still actively using the command-line tool “txt2dat” and/or the GUI interface “GUITx2d,” or if you’ve simply using LDPE for the character triangulation. Even though I haven’t had to use it very often til today, I think this is a missing feature in LDPC. I really like LDPC, but so far it doesn’t support character triangulation. I have to use a another program to generate the characters and then import them into LDPC for further processing. Since GUITx2d is somewhat outdated, the source and executable files are no longer generally available, and the program is no longer actively maintained, I’ve decided to rewrite it and integrate it into LDPC. In Image 1.1, you can see the GUITx2d dialog box integrated into the latest LDPC project from Niels. You can launch TXT2DAT by clicking on the corresponding menu item in the menu strip, which then opens the GUITx2d dialog box. Image 1.1: Project GUITx2d integrated into LDPC 1.7.7 in Visual Studio Although debugging is still in progress, the program is relatively stable and (almost) all features are functioning as intended (see Image 1.2). Image 1.2 GUITx2d integrated in LDPC 1.7.7 with triangulated text example As with the old GUITx2d program, the new one simply sends commands to the command line. Hence, the program only generates the *.DAT file, which can then be loaded into LDPC. It’s not the most elegant solution, but it works. All switches and options from TXT2DAT have been implemented, but I’ve already started adding a few new features. I’ve included the previously missing sticker bottom, which can be optionally removed. The color picker displays the names of the selected colors, and you can also triangulate characters individually -similar to the functionality found in LDPE. For now, I’ve ignored the fact that some options don’t make much sense when the program is integrated into LDPC -for example, the description field or the file name. The development is not finished right now but I guess 80% of the workis done. In case Niels is not willing to integrate my GUITx2d project into LDPC in a future release, we at least have an updated standalone version of it, which can be further improved over time. Since it already runs independently, no additional work is required at this point. What’s your take on this? Are you still actively using TXT2DAT or GUITx2d? Would you be interested in seeing it integrated with LDPC? Do you think I should move forward with the project? If there’s anything you’re missing or any feature you’d like to see added, feel free to let me know. I’d really appreciate your feedback! @Nils: I could totally understand if you don't want to include my code, but I'm happy to help where I can if you do. Thanks Gabe RE: TXT2DAT integrated in LDPC 1.7.7 - Gerald Lasser - 2025-09-10 I like the approach to include a Tx2Dat into LDPC,when I need text, so far I use tx2Dat in LDPE and move it over to LDPC RE: TXT2DAT integrated in LDPC 1.7.7 - Magnus Forsberg - 2025-09-10 I too use txt2dat in LDPE. I prefer its ability to create loose letters, without background, and the preview of the fonts. But I don't like how it adds excessive vertices. Find it hard to control the settings. RE: TXT2DAT integrated in LDPC 1.7.7 - Willy Tschager - 2025-09-11 (2025-09-10, 21:00)Gerald Lasser Wrote: I like the approach to include a Tx2Dat into LDPC,when I need text, so far I use tx2Dat in LDPE and move it over to LDPC So do I w. Software license of TXT2DAT is not compatible with LDPC - Nils Schmidt - 2025-09-11 (2025-09-10, 20:44)Gabriel Läufer Wrote: In case Niels is not willing to integrate my GUITx2d project into LDPC in a future release, we at least have an updated standalone version of it, which can be further improved over time. Since it already runs independently, no additional work is required at this point. Hi Gabriel, I really appreciate your effort to put it into LDPC! Its very nice to have this included in a future release, but remember that your code will be open source too, as a contributor of this project. There is a bigger legal caveat to it: txt2dat is published under the GNU GPL 2.0 license. Including the original txt2dat would change the license of LDPC from MIT to GPL. I don't want to do this (its also the reason I completely re-wrote txt2dat for LDPE in Java). |
