phandle prims - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Parts Tracker Discussion (https://forums.ldraw.org/forum-36.html) +--- Thread: phandle prims (/thread-26671.html) |
phandle prims - Orion Pobursky - 2022-09-07 https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=p/phandle1.dat Why is the origin where it is? The reason of "that's the way we do things for clips" isn't good enough in my opinion. Also, this phandle1 could reference phandle2 since most of the geometry is the same. In that case 2 should probably become 1 and vice versa. RE: phandle prims - Magnus Forsberg - 2022-09-07 (2022-09-07, 15:12)Orion Pobursky Wrote: Why is the origin where it is? The reason of "that's the way we do things for clips" isn't good enough in my opinion. I'll fix this then, since I edited all the parts using them, but where should the origin be? Using phandle2 inside phandle1 would add a lot of really unnecessary triangles. I don't like that. RE: phandle prims - Orion Pobursky - 2022-09-07 (2022-09-07, 16:37)Magnus Forsberg Wrote: I'll fix this then, since I edited all the parts using them, but where should the origin be? I'm not saying it needs to be changed but I do want to understand why this particular point was chosen since it seems odd. And referencing phandle2 would add a 3-4disc and 2 quads or am I wrong? RE: phandle prims - Magnus Forsberg - 2022-09-07 (2022-09-07, 16:55)Orion Pobursky Wrote: And referencing phandle2 would add a 3-4disc and 2 quads or am I wrong? phandle2 has 2 bar sized holes, and I would have to close one of them to make phandle1. RE: phandle prims - Orion Pobursky - 2022-09-07 And closing one of them should be a 3-4disc and 2 quads (or 4-4disc and relevant ering) unless I'm mistaken. RE: phandle prims - Gerald Lasser - 2022-09-07 (2022-09-07, 15:12)Orion Pobursky Wrote: https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=p/phandle1.dat Origin matched top of the plate RE: phandle prims - Orion Pobursky - 2022-09-07 (2022-09-07, 20:49)Gerald Lasser Wrote: Origin matched top of the plate Why not even with the end of the prim then instead of the middle of the hole? Nevermind, it doesn't really matter. RE: phandle prims - Orion Pobursky - 2022-09-07 (2022-09-07, 15:12)Orion Pobursky Wrote: https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=p/phandle1.dat I retract my opinion, as stated above. These primitives are fine as is. RE: phandle prims - Magnus Forsberg - 2022-09-07 (2022-09-07, 20:02)Orion Pobursky Wrote: And closing one of them should be a 3-4disc and 2 quads (or 4-4disc and relevant ering) unless I'm mistaken. Nope. |
