[LDView] LDView 4.4.1 Released - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: [LDView] LDView 4.4.1 Released (/thread-26032.html) |
LDView 4.4.1 Released - Travis Cobbs - 2022-02-11 LDView 4.4.1 is now available. You can download this release from the LDView Downloads Page. This is a minor version update, with only two changes:
RE: LDView 4.4.1 Released - Willy Tschager - 2022-05-05 Bug: * Check "Highlight selected line" in the Model Tree dialog * Chose a color different from the default light blue to highlight your lines * Lines are highligthed with the chosen color, say red * Close LDView * Start LDView * The color in the Model Tree you have chosen is still red but the selected lines are back to be highlighted with the default light blue w. RE: LDView 4.4.1 Released - Philippe Hurbain - 2022-05-05 (2022-05-05, 6:28)Willy Tschager Wrote: Bug:I don't seem to be able to reproduce the problem here
RE: LDView 4.4.1 Released - Travis Cobbs - 2022-05-05 I will investigate. I created an issue on GitHub. RE: LDView 4.4.1 Released - Travis Cobbs - 2022-05-06 (2022-05-05, 7:15)Philippe Hurbain Wrote: I don't seem to be able to reproduce the problem here I can't reproduce the problem either. Willy, are you using 64 bit LDView for Windows, or some other platform? RE: LDView 4.4.1 Released - Willy Tschager - 2022-05-06 (2022-05-06, 6:27)Travis Cobbs Wrote: I can't reproduce the problem either. Willy, are you using 64 bit LDView for Windows, or some other platform? Linux Mint 19.3 w. RE: LDView 4.4.1 Released - N. W. Perry - 2022-11-20 With macOS Monterey, LDView no longer appears to generate QuickLook previews or thumbnails. I've read that Monterey changed broke some of the QL functionality, and maybe there's something I need to do on my end? Maybe I need to copy the .qlgenerator file into my system library? RE: LDView 4.4.1 Released - Travis Cobbs - 2022-11-20 (2022-11-20, 16:59)N. W. Perry Wrote: With macOS Monterey, LDView no longer appears to generate QuickLook previews or thumbnails. I've read that Monterey changed broke some of the QL functionality, and maybe there's something I need to do on my end? Maybe I need to copy the .qlgenerator file into my system library? I don't know for sure, but I suspect that the problem is that macOS now refuses to use a QuickLook plugin inside an unsigned app. Unfortunately, I'm not willing to pay Apple $100 per year for the privilege of signing LDView. RE: LDView 4.4.1 Released - N. W. Perry - 2022-11-20 (2022-11-20, 22:07)Travis Cobbs Wrote: I don't know for sure, but I suspect that the problem is that macOS now refuses to use a QuickLook plugin inside an unsigned app. Unfortunately, I'm not willing to pay Apple $100 per year for the privilege of signing LDView. On that basis I tried deleting the com.apple.quarantine attribute from LDView, but that didn't fix QuickLook. Neither did moving the generator to my user library (can't move it to system library). RE: LDView 4.4.1 Released - Mark Kennedy - 2023-02-26 Is anybody else having problems getting the BFC display to work when lighting is turned off or is it just me? Also is there a way to make it so that the Chrome browser opens LDraw DAT files with LDView by default? If so how would this be done? RE: LDView 4.4.1 Released - Travis Cobbs - 2023-02-26 (2023-02-26, 10:09)Mark Kennedy Wrote: Is anybody else having problems getting the BFC display to work when lighting is turned off or is it just me? Because of the way it's implemented, green/red/blue BFC faces do require lighting to be enabled in order to work. I think I can update it so that this isn't the case. RE: LDView 4.4.1 Released - Mark Kennedy - 2023-02-27 (2023-02-26, 21:40)Travis Cobbs Wrote: Because of the way it's implemented, green/red/blue BFC faces do require lighting to be enabled in order to work. I think I can update it so that this isn't the case.Thanks for considering that change. |
