Part 71981,6182721,6073604,2214…… - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Part 71981,6182721,6073604,2214…… (/thread-22186.html) |
Part 71981,6182721,6073604,2214…… - yongxu wang - 2017-06-06 Hello, everyone. Yesterday I saw a post about Lego simple machinery, and in fact I needed some parts about Lego 45002. This is a list of parts I find first, and who can help me make these parts. Of course I know it will be a huge amount of work, and if you want, I can make it with building blocks. However, I need some tutorials on the network, because of the differences in language, I understand more slowly. https://brickset.com/parts/design-71981 https://brickset.com/parts/6182721/duplo-driver-cab-w-screw-6x6x2-5 https://brickset.com/parts/6073604/duplo-helicopter-cockpit https://brickset.com/parts/design-2214 https://brickset.com/parts/design-99565 https://brickset.com/parts/design-76057 https://brickset.com/parts/design-44970 https://brickset.com/parts/design-60535 https://brickset.com/parts/design-2206 https://brickset.com/parts/design-76395 https://brickset.com/parts/design-17215 https://brickset.com/parts/design-42029 https://brickset.com/parts/design-45146 https://brickset.com/parts/design-89465 https://brickset.com/parts/design-74957 https://brickset.com/parts/design-28336 https://brickset.com/parts/design-28336 https://brickset.com/parts/design-28336 RE: Part 71981,6182721,6073604,2214…… - Philippe Hurbain - 2017-06-06 Unfortunately I have none of these parts, and some are fairly complex to build... Of course we can try to help you if you try to model them! Unfortunately LDPE is sorely missing good tutorials. Maybe this one can help http://jc-tchang.philohome.com/manuel/LDPartEditor.htm ? it's written in French, but hopefully Google translate can help on this... RE: Part 71981,6182721,6073604,2214…… - yongxu wang - 2017-06-06 (2017-06-06, 8:48)Philippe Hurbain Wrote: Unfortunately I have none of these parts, and some are fairly complex to build... Of course we can try to help you if you try to model them! Unfortunately LDPE is sorely missing good tutorials. Maybe this one can help http://jc-tchang.philohome.com/manuel/LDPartEditor.htm ? it's written in French, but hopefully Google translate can help on this...Can I use SolidWorks or 3DMAX software to translate modeling into DAT format? RE: Part 71981,6182721,6073604,2214…… - Willy Tschager - 2017-06-06 (2017-06-06, 15:20)yongxu wang Wrote: Can I use SolidWorks or 3DMAX software to translate modeling into DAT format? Sure stl2dat https://sourceforge.net/projects/stl2dat/ is your friend. Don't forget to model using LDUs rather than mm or inches. w. RE: Part 71981,6182721,6073604,2214…… - Philippe Hurbain - 2017-06-06 If you don't like command line interface, you can also use LETGUI that includes Stl2Dat tool. Also note that Stl2Dat works well only with ASCII stl files, not with binary stl variant. RE: Part 71981,6182721,6073604,2214…… - yongxu wang - 2017-06-07 (2017-06-06, 18:56)Philippe Hurbain Wrote: If you don't like command line interface, you can also use LETGUI that includes Stl2Dat tool.Why flash back when I install? RE: Part 71981,6182721,6073604,2214…… - Philippe Hurbain - 2017-06-07 (2017-06-07, 4:55)yongxu wang Wrote:You mean, stl2dat or letgui? stl2dat is a command line tool, expecting command line parameters. If it has no parameters, it (very) briefly pops up a help screen and closes. To use it you should open a command line prompt, then type in the command with its parameters. If the problem is with LETGUI... I don't know. Do you have .NET installed?(2017-06-06, 18:56)Philippe Hurbain Wrote: If you don't like command line interface, you can also use LETGUI that includes Stl2Dat tool.Why flash back when I install? RE: Part 71981,6182721,6073604,2214…… - yongxu wang - 2017-06-07 (2017-06-07, 6:59)Philippe Hurbain Wrote:I installed stl2dat(2017-06-07, 4:55)yongxu wang Wrote: Why flash back when I install?You mean, stl2dat or letgui? stl2dat is a command line tool, expecting command line parameters. If it has no parameters, it (very) briefly pops up a help screen and closes. To use it you should open a command line prompt, then type in the command with its parameters. If the problem is with LETGUI... I don't know. Do you have .NET installed? RE: Part 71981,6182721,6073604,2214…… - Philippe Hurbain - 2017-06-07 (2017-06-07, 9:00)yongxu wang Wrote: I installed stl2datThen you must use a command line prompt. But it you are not comfortable with this, install LETGUI instead! [url=https://www.lifewire.com/how-to-open-command-prompt-2618089][/url] Quote:Don't forget to model using LDUs rather than mm or inches.Note: 1ldu = 0.4mm |
