LDD to MLCAD file conversion help - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: LDD to MLCAD file conversion help (/thread-22124.html) |
LDD to MLCAD file conversion help - Luis - 2017-03-25 Hello, I am new to this community and to LDraw, MLCAD, etc. I downloaded both the LDraw complete installer and LDD. I am trying to convert my design on LDD (.lxf) to MLCAD (.ldr), I think. However, when I do this, LDD gives me an error message: "Warning: Unable to export model" I am confused as to why I can't export the LDD model to MLCAD. Any help is greatly appreciated. LDD file attached. (Hopefully I did it right and it works). Thanks!
RE: LDD to MLCAD file conversion help - Philippe Hurbain - 2017-03-26 Welcome here, Luis! No idea... is it possible that you share your model file to make tests? RE: LDD to MLCAD file conversion help - Luis - 2017-03-26 (2017-03-26, 11:34)Philippe Hurbain Wrote: Welcome here, Luis! Sorry, I'm new at this. What do you mean "to make tests"? Also, by sharing do you mean I share my model on the forum? Thanks again. RE: LDD to MLCAD file conversion help - Philippe Hurbain - 2017-03-26 I meant i'd like to try here to export your file to LDraw to understand what could get wrong. So if you can post your lxf file to this forum as attachment or as a link... RE: LDD to MLCAD file conversion help - Luis - 2017-03-26 (2017-03-26, 14:16)Philippe Hurbain Wrote: I meant i'd like to try here to export your file to LDraw to understand what could get wrong. So if you can post your lxf file to this forum as attachment or as a link... I don't know how to attach the file. I tried using brickshelf.com, but they never sent me an account confirmation email. Can you walk me through uploading the LDD file? RE: LDD to MLCAD file conversion help - Philippe Hurbain - 2017-03-26 (2017-03-26, 15:17)Luis Wrote: I don't know how to attach the file. I tried using brickshelf.com, but they never sent me an account confirmation email. Can you walk me through uploading the LDD file?Click on "Browse" button (bottom left of reply window), navigate on your computer to find your file, then when you're done click on "Add attachment" (bottom right of reply window). Then "Post Reply"... RE: LDD to MLCAD file conversion help - Luis - 2017-03-26 (2017-03-26, 15:31)Philippe Hurbain Wrote:(2017-03-26, 15:17)Luis Wrote: I don't know how to attach the file. I tried using brickshelf.com, but they never sent me an account confirmation email. Can you walk me through uploading the LDD file?Click on "Browse" button (bottom left of reply window), navigate on your computer to find your file, then when you're done click on "Add attachment" (bottom right of reply window). Then "Post Reply"... I tried, but it gives a message saying "Please correct the following errors before continuing: The type of file that you attached is not allowed. Please remove the attachment or choose a different type." RE: LDD to MLCAD file conversion help - Philippe Hurbain - 2017-03-26 Quote:I tried, but it gives a message saying "Please correct the following errors before continuing: The type of file that you attached is not allowed. Please remove the attachment or choose a different type."Ah - yes, indeed, forum doesn't allow .lxf files! Please compress it as a zip, or change file type (file extension) to .txt, that should work. RE: LDD to MLCAD file conversion help - Luis - 2017-03-26 (2017-03-26, 16:25)Philippe Hurbain Wrote:Quote:I tried, but it gives a message saying "Please correct the following errors before continuing: The type of file that you attached is not allowed. Please remove the attachment or choose a different type."Ah - yes, indeed, forum doesn't allow .lxf files! Please compress it as a zip, or change file type (file extension) to .txt, that should work. I think this should work:
Lego Spaceship LDD (Final, Unfinished).zip (Size: 666.83 KB / Downloads: 6)
RE: LDD to MLCAD file conversion help - Philippe Hurbain - 2017-03-26 [quote pid='24952' dateline='1490546205'] I think this should work: [/quote] Doesn't seem so. Attachment seems to have no relationship with a normal LDD .lxf file... How did you got it? RE: LDD to MLCAD file conversion help - Luis - 2017-03-26 (2017-03-26, 17:10)Philippe Hurbain Wrote: [quote pid='24952' dateline='1490546205']Doesn't seem so. Attachment seems to have no relationship with a normal LDD .lxf file... How did you got it? [/quote] I emailed the LDD file to myself because I had to get a new laptop. I downloaded the file from my email. It seems to work fine in the program, but it can't convert to LDraw for some reason. Perhaps the email changed the file somehow? In the email attachment, it says ".lxf". To convert it to a .zip file, I did "Export BOM" on the LDD program and chose to save it as a zip file. Then I attached the zip file to my reply. RE: LDD to MLCAD file conversion help - Philippe Hurbain - 2017-03-26 (2017-03-26, 17:22)Luis Wrote:(2017-03-26, 17:10)Philippe Hurbain Wrote: [quote pid='24952' dateline='1490546205']Doesn't seem so. Attachment seems to have no relationship with a normal LDD .lxf file... How did you got it? I emailed the LDD file to myself because I had to get a new laptop. I downloaded the file from my email. It seems to work fine in the program, but it can't convert to LDraw for some reason. Perhaps the email changed the file somehow? In the email attachment, it says ".lxf". To convert it to a .zip file, I did "Export BOM" on the LDD program and chose to save it as a zip file. Then I attached the zip file to my reply. [/quote] OK, so actually you attached the bill of material, not the model! Right click on the .lxf file, then choose "add to compressed folder" to create a zip, and attach this zip file. RE: LDD to MLCAD file conversion help - Luis - 2017-03-26 (2017-03-26, 18:03)Philippe Hurbain Wrote:OK, so actually you attached the bill of material, not the model! Right click on the .lxf file, then choose "add to compressed folder" to create a zip, and attach this zip file.(2017-03-26, 17:22)Luis Wrote: Doesn't seem so. Attachment seems to have no relationship with a normal LDD .lxf file... How did you got it? [/quote] Ok:
Lego Spaceship Zip.zip (Size: 134.27 KB / Downloads: 5)
RE: LDD to MLCAD file conversion help - Philippe Hurbain - 2017-03-26 Better... But the LDD model looks weird, as if it was exploded (shipLDD image attached) The good news is that after beeing exported to LDraw it looks the same (shipLDCad image) Also attached the converted file. RE: LDD to MLCAD file conversion help - Luis - 2017-03-26 (2017-03-26, 18:43)Philippe Hurbain Wrote: Better... But the LDD model looks weird, as if it was exploded (shipLDD image attached) Thanks! On my phone right now, will try it later. The model is supposed to look like that, I build the ship in separate chunks RE: LDD to MLCAD file conversion help - Luis - 2017-03-27 For future reference: How can I export my LDD files to .ldr without using the LDD program? I'm wondering if there is another option before I email Lego customer support. |
