New Theme Choice - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Administrative (https://forums.ldraw.org/forum-4.html) +--- Forum: Website Suggestions/Requests/Discussion (https://forums.ldraw.org/forum-23.html) +--- Thread: New Theme Choice (/thread-21983.html) |
New Theme Choice - Orion Pobursky - 2017-01-13 I found a new theme for the forums that might be liked better by some. It's a bit less white and more grey like the old forums software. I still have to do some modifications to it (e.g. some images are broken) but you can give it a test drive. - Go to User CP - In the sidebar under "Your Profile" click "Edit Options" - On the right under "Other Options" change "Board Style" to "stb" - Click Update Options Please let me know what you think and if you notice any broken images which seems to be the biggest issue right now. RE: New Theme Choice - Philippe Hurbain - 2017-01-13 (2017-01-13, 4:17)Orion Pobursky Wrote: Please let me know what you think and if you notice any broken images which seems to be the biggest issue right now.Personnaly I kind of prefer "regular" theme - especially the explicit blue text for links. With the new theme you have to mouse over to discover -by chance- that there is a link... Otherwise, the search box is missing (as well as banner/link to LDraw website) RE: New Theme Choice - Max Martin Richter - 2017-01-17 (2017-01-13, 4:17)Orion Pobursky Wrote: I found a new theme for the forums that might be liked better by some. It's a bit less white and more grey like the old forums software. I still have to do some modifications to it (e.g. some images are broken) but you can give it a test drive. Would you please so kind and add the "purge spammer" button to the new theme?! ;-) RE: New Theme Choice - Orion Pobursky - 2017-01-17 (2017-01-17, 13:39)Max Martin Richter Wrote: Would you please so kind and add the "purge spammer" button to the new theme?! ;-) I'm confused on what you are referring to. RE: New Theme Choice - Orion Pobursky - 2017-01-17 (2017-01-13, 12:04)Philippe Hurbain Wrote:(2017-01-13, 4:17)Orion Pobursky Wrote: Please let me know what you think and if you notice any broken images which seems to be the biggest issue right now.Personnaly I kind of prefer "regular" theme - especially the explicit blue text for links. With the new theme you have to mouse over to discover -by chance- that there is a link... I think I might "bleed" some of the color scheme into the default theme. There's also functionality to have different "color only" themes with the same underlying html. RE: New Theme Choice - Orion Pobursky - 2017-01-18 (2017-01-17, 23:30)Orion Pobursky Wrote:(2017-01-17, 13:39)Max Martin Richter Wrote: Would you please so kind and add the "purge spammer" button to the new theme?! ;-) Nevermind, I figured it out. It doesn't show up with users who have greater than 10 posts. That said, I don't think the new theme will stick around for very long as I found a way to "reskin" the main theme. RE: New Theme Choice - Max Martin Richter - 2017-01-18 (2017-01-18, 3:35)Orion Pobursky Wrote:(2017-01-17, 23:30)Orion Pobursky Wrote: I'm confused on what you are referring to. Strange, I had a spammer with exactly one post. So I decided to switch the theme to the old one temporally. /Max |
