2013-01-28, 0:28
Pages: 1 2
2013-01-28, 0:32
6911 - Mini Fire Truck - Ladder Truck.ldr
6911 - Mini Fire Truck - Rescue Helicopter.ldr
6911 - Mini Fire Truck - Rescue SUV.ldr
2013-01-28, 0:34
7601 - Go-Kart.ldr
7602 - Jeep.ldr
7603 - Dump Truck.ldr
7803 - Red Jeep.ldr
7808 - Yellow Airplane.ldr
7602 - Jeep.ldr
7803 - Red Jeep.ldr
2013-01-28, 0:34
7875 - Backhoe.mpd
2016-01-01, 17:18
2016-01-18, 20:04
Not OMR. Code above header in all subparts
2016-01-19, 7:59
Corrected. Was before finding an issue in MPDCenter, occuring with headerless subfiles.
2016-12-31, 15:06
31045 - Ocean Explorer [Creator, 2016]
Download MPD (OMR compliant)
Known errors: None
Done with: LDCad 1.6 Beta 1a
31045 - Ocean Explorer - Aircraft [Creator, 2016]
Known errors: None
31045 - Ocean Explorer - Submarine [Creator, 2016]
Known errors: None
Known errors: None
Known errors: None
Known errors: None
2017-06-24, 19:00
2018-03-24, 16:50
Download MPD
Known errors: None (now updated to include missing tail!)
Done with LDCad 1.6b
Download MPD
Known errors: None
Download MPD
Known errors: None
2018-10-16, 14:54
30542 - Cute Pug
MPD (Direct link) - OMR Compliant.
Building instructions and parts list on BrickHub.org
Made using stud.io 2.0 with rotation steps made using emacs (And using BrickHub.org to verify rotations).
2018-10-16, 15:19
Whoa! I was not aware of Brickhub, on line instructions look great! Thanks for the heads up
Perhaps you should re-render with a sightly lower light level, pug's back is washed out...
2018-10-16, 18:19
(2018-10-16, 15:19)Philippe Hurbain Wrote: [ -> ]Whoa! I was not aware of Brickhub, on line instructions look great! Thanks for the heads up
Thanks. It is a whole new project I started after moving and not having physical bricks with me for a while.
It it still under development, so please tell me if you find any errors or wishes for functionality. As an example, I did not know you were allowed to not have '.ldr' or '.dat' as ldr sub-file names, which resulted in errors when I imported directly from Stud.io to Brickhub. Now I have to fix that once I get back to my own machine next Tuesday.
Stud.io is also completely new for me. The renderer seems to make pictures that are either too bright or too dark. I must see what others have done to solve that issue. BTW. It is because of your review that I considered getting into stud.io in the first place.
For now I will try to build as many official models as time permits before Tuesday - the more instructions there are on Brickhub, the better the base is for generating automatic instructions.
Edit: B-models is done:
30542 Koala
Direct link to .mpd file - OMR Compliant.
Again made using stud.io 2.0 and emacs.
30542 Turkey
Made using stud.io 2.0 and emacs.
2018-11-13, 13:40
(2018-10-16, 14:54)Lasse Deleuran Wrote: [ -> ]30542 - Cute Pug
BrickHub... very interesting for this kind of cute little models. I Like it!
I see some larger models too. Very nice indeed.
2018-11-13, 14:15
(2018-11-13, 13:40)Jaco van der Molen Wrote: [ -> ](2018-10-16, 14:54)Lasse Deleuran Wrote: [ -> ]30542 - Cute Pug
P.S. I have been so free to create an account and upload set 40252 the mini VW Beetle...
2018-11-13, 14:55
(2018-11-13, 14:15)Jaco van der Molen Wrote: [ -> ](2018-11-13, 13:40)Jaco van der Molen Wrote: [ -> ]BrickHub... very interesting for this kind of cute little models. I Like it!
2018-12-09, 11:18
Download MPD
Known errors: None
Rendered with Studio 2.0
Download MPD
Known errors: None
Download MPD
Known errors: None
2018-12-09, 19:14
(2018-12-09, 11:18)Philippe Hurbain Wrote: [ -> ]
Download MPD
Known errors: None
Download MPD
Known errors: None
Download MPD
Known errors: None
Hi Philippe,
Do you upload your models to the OMR too?
Jaco
2018-12-09, 19:25
(2018-12-09, 19:14)Jaco van der Molen Wrote: [ -> ](2018-12-09, 11:18)Philippe Hurbain Wrote: [ -> ]
Download MPD
Known errors: None
Download MPD
Known errors: None
Download MPD
Known errors: None
Hi Philippe,
Jaco
I think not.
That's our job.
2019-01-05, 17:54
Download MPD
Known errors: None
Download MPD
Known errors: None
Download MPD
Known errors: None
2019-01-05, 20:47
Great render of really pretty set. And with both alternatives - great job, Philippe!
One detail bothers me: the curved rail part in the main model looks flying above the rail.
Otherwise, it's simply awesome. you made me feeling I definitely need one Xmas present more
2019-01-06, 8:24
(2019-01-05, 20:47)Milan Vančura Wrote: [ -> ]Great render of really pretty set. And with both alternatives - great job, Philippe!Thanks for spotting that one Milan! The MPD file is correct, the problem lies in Studio LDraw import
Though Studio library is LDraw based, there are discrepancies: some parts that didn't exist in LDraw have been outsourced and added to library. This of course makes sense. The only problem is that some of them have origin/orientation which don't use LDraw conventions, or even use plain stupid ones, so when these parts are later added to LDraw library they are not compatible. See for example the new gearbox parts, as I reported here (but this message got no echo )
As I love Studio renderer, I looked for a way to get around this problem. I use a brute force method, which is to dump all unofficial parts in Studio custom parts folder, so that Studio can display them even if they are missing from it's base library, and ALSO to Studio unofficial folder, to overwrite the parts that are different from LDraw ones. Of course this breaks compatibility with Studio files, but I don't care...
The case of the curved fence is worse, because an outsourced file with stupid origin makes its way to Studio official parts folder!!! And I didn't noticed the wrong image...
I'll update the renders! Now re-rendered and updated.
2019-01-06, 14:36
2019-01-06, 16:34
Wow!!
That view from the inside is "incroyable".
2019-01-08, 17:01
Ah, I didn't know about this crazy incompatibility. I'm "Happy Linux user": no Studio for my platform, no problems
Thanks for the update, it looks really awesome. I can understand why you like renders from Studio...
2019-06-05, 8:37
2019-06-05, 8:42
(2019-06-05, 8:37)Jaco van der Molen Wrote: [ -> ]Work in progress for 10266
Question about this one: there is a part in Titanium Metallic (Tub, #64951).
I cannot find in LDraw. What color would that be?
I am planning and trying to buy this set, so I can do the Stickers and patterns too.
A good exercise for me in getting to know LDPC ;-)
2019-06-05, 9:26
(2019-06-05, 8:42)Jaco van der Molen Wrote: [ -> ]Question about this one: there is a part in Titanium Metallic (Tub, #64951).Titanium metallic is mapped to LDraw 87:
0 // LEGOID 337 - Titanium
0 !COLOUR Metallic_Dark_Grey CODE 87 VALUE #6D6E5C EDGE #333333
Quote:A good exercise for me in getting to know LDPC ;-)Yes
2019-06-05, 12:58
(2019-06-05, 9:26)Philippe Hurbain Wrote: [ -> ]Titanium metallic is mapped to LDraw 87:
...in latest, still unofficial LDconfig.ldr (https://forums.ldraw.org/thread-23434-po...l#pid32282)Code:0 // LEGOID 337 - Titanium
Yes
Tnx Philo! I had the new LDConfig, but must have overlooked this color.
I found a reasonable photo of the stickersheet on Brickset, but it is somewhat curved. I'll see what I can make of it.
Next question: I think these parts are in the library but under another number
https://brickset.com/parts/design-28919
https://brickset.com/parts/design-28918
I cannot seem to find them. Are they made?
2019-06-05, 13:18
(2019-06-05, 12:58)HJaco van der Molen Wrote: [ -> ]Tnx Philo! I had the new LDConfig, but must have overlooked this color.
Did you try 11290 and 11301? I can’t view them right now but both are in the library.
2019-06-05, 14:50
(2019-06-05, 13:18)Orion Pobursky Wrote: [ -> ]Did you try 11290 and 11301? I can’t view them right now but both are in the library.
Ah yes, found them! Should we create new aliases with the new partnumber?
Model is done:
[attachment=3721]
Now for the stickers...
2019-06-05, 15:12
(2019-06-05, 14:50)Jaco van der Molen Wrote: [ -> ]Ah yes, found them! Should we create new aliases with the new partnumber?If there is no significant difference, yes (Bricklink makes them completely equivalent)
2019-06-05, 22:05
(2019-06-05, 14:50)Jaco van der Molen Wrote: [ -> ]Now for the stickers...
Yes,
In this set you have to use the Chrome Gold on some of the stickers, since they're printed
on a shiny, highly reflective foil, not paper.
2019-06-06, 6:15
(2019-06-05, 22:05)Magnus Forsberg Wrote: [ -> ]Yes,
I see. That would mean hard code color Chrome_Gold LDraw code 334, right?
2019-06-06, 7:24
(2019-06-06, 6:15)Jaco van der Molen Wrote: [ -> ]I see. That would mean hard code color Chrome_Gold LDraw code 334, right?
Yes.
There are some really good pictures in the review at New Elementary.
2019-06-06, 14:30
(2019-06-06, 7:24)Magnus Forsberg Wrote: [ -> ]Yes.
OK, but I'll need a good flat image of the stickers. I am planning to buy the set, but am in doubt where and when.
Does someone have it and still stickers on the sheet? Please scan or photograph as flat as possible. And the minifig torso's too.
Other question: should I model the stickers with round corners or straight 90-degree angle?
2019-06-16, 16:16
Download MPD File
Building instructions + parts list
Known errors: None
Build in Studio 2.0
OMR-conform and step rotations using Brickhub.org
2019-06-16, 21:09
The Pelican is such a great set for it's size! I brought it from Billund and I find it amazing!
2019-06-16, 21:11
Jaco, check those ones out as well:
https://zusammengebaut.com/wp-content/up...ehmann.jpg
May be if you contact Andres, he can provide you with a higher res picture.
BB also have a good one:
https://s3-us-west-2.amazonaws.com/media...der-42.jpg
2019-06-17, 10:26
(2019-06-16, 21:11)Gerald Lasser Wrote: [ -> ]Jaco, check those ones out as well:
Ah, yes! That is what I need! Thanks Gerald.
2019-10-31, 21:23
Super Soarer
[attachment=4158]
Helicoptor
[attachment=4153]
Speed Boat
[attachment=4154]
All files are OMRcompliant
Done with LDCaD 1.6c
Render with Studio2.0
[attachment=4158]
Helicoptor
[attachment=4153]
Speed Boat
[attachment=4154]
2019-11-24, 20:39
Many reference to 4896 - Roaring Roadsters in OMR file reference but mpd file not downloadable !?
Set 4896 - Roaring Roadsters - Roadster
[attachment=4339]
[attachment=4271]
OMR compliant : Yes
Known error : None
[attachment=4339]
[attachment=4271]
OMR compliant : Yes
Known error : None
2019-11-29, 2:33
Race Car
[attachment=4286]
Hot Rod
[attachment=4287]
Speedboat
[attachment=4288]
All files are OMR compliant
Done with LDCad 1.6c
Rendered with Studio2.0
[attachment=4286]
Hot Rod
[attachment=4287]
Speedboat
[attachment=4288]
2019-11-29, 3:27
(2019-11-29, 2:33)Marc Belanger Wrote: [ -> ]Gotta learn Studio 2.0 - Your renders are marvelous
Nothing much to learn. Just load the file, hit render, position as desired, and hit go. Viola.
2019-11-30, 22:08
Helicopter
[attachment=4289]
Power Boat
[attachment=4290]
Glider Plane
[attachment=4291]
[attachment=4289]
Power Boat
[attachment=4290]
Glider Plane
[attachment=4291]
2019-12-01, 16:39
4417 - Mini Robots
[attachment=4295]
[attachment=4296]
[attachment=4297]
[attachment=4298]
[attachment=4299]
[attachment=4300]
All files OMR compliant.
[attachment=4295]
[attachment=4296]
[attachment=4297]
[attachment=4298]
[attachment=4299]
[attachment=4300]
2019-12-03, 20:03
4891 - Highway Haulers 1/2
[attachment=4303]
[attachment=4305]
[attachment=4306]
[attachment=4307]
[attachment=4308]
[attachment=4309]
OMR compliant : Yes
[attachment=4303]
[attachment=4305]
[attachment=4306]
[attachment=4307]
[attachment=4308]
[attachment=4309]
OMR compliant : Yes
2019-12-03, 20:06
4891 - Highway Haulers 2/2
OMR compliant : Yes
and
[attachment=4311]
[attachment=4312]
[attachment=4313]
[attachment=4314]
[attachment=4315]
[attachment=4316]
OMR compliant : Yes
and
[attachment=4311]
[attachment=4312]
[attachment=4313]
[attachment=4314]
[attachment=4315]
[attachment=4316]
2019-12-04, 21:29
3 more houses :
[attachment=4319]
[attachment=4320]
[attachment=4321]
[attachment=4322]
[attachment=4323]
[attachment=4324]
OMR compliant : Yes
To do list : secondary model (3 in 1 serie)
[attachment=4319]
[attachment=4320]
[attachment=4321]
[attachment=4322]
[attachment=4323]
[attachment=4324]
OMR compliant : Yes
2019-12-06, 13:13
31025 Mountain Hut (A model of 3in1)
Should be OMR compliant.
Done with LDCad 1.6c, no known issues (but B models not included).
Pages: 1 2
