2019-12-07, 2:13
Pages: 1 2
2019-12-08, 12:58
31048 Lakeside Lodge (A model of 3in1)
Should be OMR compliant.
Done with LDCad 1.6c.
Questions / known issues:
- Face of MiniFig has wrong pattern (could not find correct one in library). I already looked at Rebrickable and BrickLink without success - what is the best way to find the correct one?
- Shirt of MiniFig seems to have pattern of 973pdd like in 31038 (officially downloadable OMR), but color of stripes is red. Are my eyes getting bad, or should the stripes be red in 31038, too? I added the 973pdd in the mpd file with changed color - is this the way it should be done?
- BrickLink and Rebrickable show "98313" for the moose's antlers, but LDraw-item seems to be 76116.
- no B models.
Thanks for any suggestion.
Edit: removed old version of mpd, fixed one is below.
- no B models.
2019-12-08, 16:11
(2019-12-08, 12:58)Stefan Frenz Wrote: [ -> ]- Face of MiniFig has wrong pattern (could not find correct one in library). I already looked at Rebrickable and BrickLink without success - what is the best way to find the correct one?The correct head is 3626cp8i.dat. I found it by looking at Bricklink description and looked for "lopsided" in LDraw parts. We now try to include Bricklink reference as keyword, but this older part doesn't include it.
Quote:- Shirt of MiniFig seems to have pattern of 973pdd like in 31038 (officially downloadable OMR), but color of stripes is red. Are my eyes getting bad, or should the stripes be red in 31038, too? I added the 973pdd in the mpd file with changed color - is this the way it should be done?Printed part color is always difficult to assert, especially on dark colors (paint is partially transparent). 973pdd uses brown, which seems to visually match most images I could see on the web (eg. https://youtu.be/VMRLd7V4CoI?t=29 ). Notable exception is LEGO image https://www.lego.com/service/bricks/5/2/6155272 but it's computer generated, so no real life transparency
Quote:- BrickLink and Rebrickable show "98313" for the moose's antlers, but LDraw-item seems to be 76116.Now on PT: https://www.ldraw.org/cgi-bin/ptdetail.c.../98313.dat. Note that Brickset (whose data comes from LEGO) uses 76116 reference. I have also sent an updated 76116 to part admin.
2019-12-08, 16:21
Again thank you very much, Philippe!
Now fixed head and reverted shirt to 973pdd with brown stripes (still not sure even by looking at the real part).
Edit: fixed subfile headers.
2019-12-12, 1:57
Shark
[attachment=4416]
Squid
[attachment=4417]
Angler Fish
[attachment=4418]
Extra Building Instructions: Whale
[attachment=4419]
All files are OMR compliant
Rendered with Studio 2.0
[attachment=4416]
Squid
[attachment=4417]
Angler Fish
[attachment=4418]
[attachment=4419]
2019-12-22, 16:07
Fixed tyre color: Black => Rubber Black.
At the moment, this model is not yet in the OMR database. Is it correct to skip the HISTORY-tag for this change or should it be included even if it is not official yet?
2019-12-22, 23:19
(2019-12-22, 16:07)Stefan Frenz Wrote: [ -> ]Fixed tyre color: Black => Rubber Black.
Don't worry about it. HISTORY tags are optional for the OMR and the standards a far looser than the PT.
2019-12-30, 0:24
Fixed 1x1 Clip color Black => Dark Bluish Gray,
fixed main ldr sub-filename to comply with OMR rules (hopefully, and I hope it is ok to leave the "-1" for this model to not-change the filename of an already uploaded file).
2019-12-30, 0:37
(2019-12-06, 13:13)Stefan Frenz Wrote: [ -> ]31025 Mountain Hut (A model of 3in1)Attached is first 31025 Mountain Hut B-model "Small Lodge".
(but B models not included).
Done with LDCad 1.6c, file should be OMR compliant (I hope it is ok to leave the "-1" for this model to have the same set-number as the already uploaded file for the A-model).
Known issues: none.
2020-01-04, 11:00
(2019-12-06, 13:13)Stefan Frenz Wrote: [ -> ]B models not included.Attached is second 31025 Mountain Hut B-model "Mountaintop Lookout".
Known issues: none.
2020-01-07, 17:50
31048 Lakeside Lodge - Observatory (first B model of 3in1)
File should be OMR compliant (I hope that it's ok to keep the "-1" to have the number of the A model).
Done with LDCad 1.6c, known issues: none.
2020-01-07, 17:51
31048 Lakeside Lodge - Small Cabin (second B model of 3in1)
2020-01-21, 21:03
4883 - Gear Grinders
6 Quick Build Models
[attachment=4694]
[attachment=4688]
[attachment=4689]
[attachment=4690]
[attachment=4691]
[attachment=4692]
[attachment=4693]
Files OMR compliant
Known error : None
Made with LDCad (my good resolution of this year !)
[attachment=4694]
[attachment=4688]
[attachment=4689]
[attachment=4690]
[attachment=4691]
[attachment=4692]
[attachment=4693]
Files OMR compliant
Known error : None
2020-01-21, 21:06
(2020-01-21, 21:03)Marc Giraudet Wrote: [ -> ]4883 - Gear Grinders
6 Experienced Build Models
[attachment=4702]
[attachment=4696]
[attachment=4697]
[attachment=4698]
[attachment=4699]
[attachment=4700]
[attachment=4701]
Files OMR compliant
Known error : None
Made with LDCad
2020-01-21, 21:09
5 Advanced Models
[attachment=4708]
[attachment=4703]
[attachment=4704]
[attachment=4705]
[attachment=4706]
[attachment=4707]
Files OMR compliant
Known error : None
Made with LDCad
5 Advanced Models
[attachment=4708]
[attachment=4703]
[attachment=4704]
[attachment=4705]
[attachment=4706]
[attachment=4707]
Files OMR compliant
Known error : None
Made with LDCad
2020-01-22, 8:47
17 models for a 273 pcs set... wow!
2020-01-24, 17:52
4954 - Models 2 and 3
[attachment=4716]
[attachment=4715]
[attachment=4718]
[attachment=4717]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size]
[attachment=4716]
[attachment=4715]
[attachment=4718]
[attachment=4717]
2020-01-24, 21:58
[attachment=4724]
4954 New file with updated windcreen car color (transblack) and other minor correction
2020-01-25, 13:19
4956 - Models 2 and 3
[attachment=4727]
[attachment=4726]
[attachment=4730]
[attachment=4729]
And model 1 with minor correction (use new door part 47899c01 / 73194c01)
[attachment=4728]
[attachment=4727]
[attachment=4726]
[attachment=4730]
[attachment=4729]
[attachment=4728]
2020-01-27, 22:10
4996 - Models 2 and 3
[attachment=4747]
[attachment=4746]
[attachment=4749]
[attachment=4748]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studio[/font][/size]
[attachment=4747]
[attachment=4746]
[attachment=4749]
[attachment=4748]
2020-01-30, 22:57
4896 models 2 and 3
[attachment=4757]
[attachment=4756]
[attachment=4755]
[attachment=4754]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size][/font][/size]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size][/font][/size]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studio[/font][/size][/font][/size]
[attachment=4757]
[attachment=4756]
[attachment=4755]
[attachment=4754]
2020-01-31, 21:07
(2019-11-24, 20:39)Marc Giraudet Wrote: [ -> ]Set 4896 - Roaring Roadsters - Roadster[attachment=4764]
File with minor correction. Part and color updated.
2020-02-07, 18:57
4404 - Land Busters
3 models
[attachment=4798]
[attachment=4799]
[attachment=4795]
[attachment=4794]
[attachment=4797]
[attachment=4796]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studi[/font][/size][/font][/size][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]o[/font][/size][/font][/size]
3 models
[attachment=4798]
[attachment=4799]
[attachment=4795]
[attachment=4794]
[attachment=4797]
[attachment=4796]
2020-02-09, 11:12
31031 - Rainforest Animals
[attachment=4816]
[attachment=4815]
[attachment=4814]
[attachment=4813]
[attachment=4812]
[attachment=4811]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size][/font][/size][/font][/size]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size][/font][/size][/font][/size]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studi[/font][/size][/font][/size][/font][/size][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]o[/font][/size][/font][/size][/font][/size]
[attachment=4816]
[attachment=4815]
[attachment=4814]
[attachment=4813]
[attachment=4812]
[attachment=4811]
2020-02-09, 22:24
31038 - Changing Seasons
[attachment=4824]
[attachment=4823]
[attachment=4826]
[attachment=4825]
[attachment=4822]
[attachment=4821]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size][/font][/size][/font][/size][/font][/size]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size][/font][/size][/font][/size][/font][/size]
[size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studi[/font][/size][/font][/size][/font][/size][/font][/size][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]o[/font][/size][/font][/size][/font][/size][/font][/size]
[attachment=4824]
[attachment=4823]
[attachment=4826]
[attachment=4825]
[attachment=4822]
[attachment=4821]
2020-03-10, 21:29
2020-03-14, 11:51
Main model of 31009: Small Cottage
Done with LDCad 1.6c (Linux64).
File should be OMR compliant.
Known issues: none.
Known issues: none.
2020-03-15, 17:47
B-Models of 31009: Skater's House and Windmill.
Files should be OMR compliant.
Known issues: none.
Known issues: none.
2020-05-04, 22:53
Twin Spin Helicopter
[attachment=5176]
Snowmobile
[attachment=5177]
Single-Engine Airplane
[attachment=5178]
[attachment=5176]
Snowmobile
[attachment=5177]
[attachment=5178]
2021-04-03, 18:54
2021-04-03, 18:55
2021-04-03, 18:58
2021-04-03, 21:16
2021-04-03, 21:17
2021-04-03, 21:18
2021-04-18, 13:01
2021-04-18, 13:04
2021-04-18, 13:06
2021-04-25, 17:20
2021-04-25, 17:23
7347 - Highway Pickup - Truck
[attachment=6394]
[attachment=6393]
File OMR compliant
Known error : None
[attachment=6394]
[attachment=6393]
File OMR compliant
Known error : None
2021-04-25, 17:49
7347 - Highway Pickup - Car
[attachment=6396]
[attachment=6395]
File OMR compliant
Known error : None
[attachment=6396]
[attachment=6395]
File OMR compliant
Known error : None
2021-05-19, 6:32
31070 - Turbo Track Racer (2017)
Done with LDCad 1.6d (Linux64)
Known errors: none.
Known errors: none.
2022-09-02, 6:27
2022-10-11, 1:04
May I suggest/request that this thread be split by year as well? The Creator theme has been around a long time now…
2022-10-11, 4:46
I agree. Thread Locked. Please post new model under Creator <year>
Pages: 1 2
