2024-01-06, 21:31
thanks for recet fast add ... its possible also to make this:
35757c01pb01
Mouse with Light Nougat Tail, Black Eyes and Bright Pink Nose Pattern
35757c01pb01
(2024-01-06, 22:24)Gerald Lasser Wrote: [ -> ]Unfortunately I cannot find a raws file for the mouse
(2024-01-07, 13:02)Rene Rechthaler Wrote: [ -> ]some other raw files can be found here:
http://www.digital-bricks.de/index.php?site=nil
(from about 2000-2015, unpatterned and uncleaned files, some are already done)
(2024-01-08, 18:40)Rene Rechthaler Wrote: [ -> ]I dont know where and how this data got extracted
(2024-01-11, 3:36)Javier Orquera Wrote: [ -> ]Hello, attached is the raw files. As always, need clean and maybe the scale and origin are wrong.
(2024-01-11, 8:14)Dario Wrote: [ -> ]thanks!!! i try to understand how make pattern and wait if someone are able to do...very unfriendly software... theres somewhere a video tutorial to understand how add pattern?
(2024-01-11, 11:53)Dario Wrote: [ -> ]very unfriendly software... theres somewhere a video tutorial to understand how add pattern?
(2024-01-12, 8:00)Fredrik Hareide Wrote: [ -> ]In my opinion Blender is the way to go for adding patterns. What pattern are you going to make?If Blender works i try,
(2024-01-12, 8:22)Dario Wrote: [ -> ]If Blender works i try,
Eye and nose Pattern
I know graphic software but i necer use 3d software
(2024-01-12, 8:28)Fredrik Hareide Wrote: [ -> ]I'm happy to help with Blender if you have the 2d version of the pattern. And reference imageyes for sure i works on it and i send you, thanks
(2024-01-12, 12:47)Dario Wrote: [ -> ]yes for sure i works on it and i send you, thanks
(2024-01-12, 13:42)Dario Wrote: [ -> ]you need png or an vector illustrator file?
(2024-01-12, 14:30)Gerald Lasser Wrote: [ -> ]Well, it SW to build bricks and pieces.
The link in the wiki to JC Tchang's LDPE documentation is good and Google does a good job transalting it from French
To create patterns, it is better to use LD Pattern Creator first, where you have a 2D Canvas which can be projected onto a 3D surface. There is also an explanation of LDPC at JC Tchang here: https://jc-tchang.philohome.com/manuel/LPC_a.htm also in French, but Google Transalte again is doing pretty well.
To use a 3D Template, these surfaces need to be extracted from the model first, see attachment 35757s99.dat in the attachment.
This needs to be imported into LDPC:
File > Import from DAT > Project on YZ Plane (+X Left)
Choose "Overwrite and Import Projection Data"
You then see the outline of the partial head of the mouse
You can draw now the Eye
To export follow JC Tchangs documentation
TO join the surface and the mouse it is best to use LDPE again
(2024-01-12, 14:44)Dario Wrote: [ -> ]it easy for you but not for me.. : )
(2024-01-12, 22:12)Fredrik Hareide Wrote: [ -> ]Did a quick test in Blender and should absolutely be doable but mesh needs some cleaning and splitting and renaming first I guess.thx for try.
(2024-01-12, 22:25)Dario Wrote: [ -> ]thx for try.
i hope someone make it... i try to understand but seem very hard for me to make also very easy step.
seem software from another time... : ))
(2024-01-17, 12:10)Fredrik Hareide Wrote: [ -> ]Now on PT! https://library.ldraw.org/tracker/34051
Thanks to Philo for preparing and cleaning the mesh!
(2024-01-17, 12:22)Dario Wrote: [ -> ]thanks!!!i make some mistake?
(2024-01-17, 15:09)Dario Wrote: [ -> ]i make some mistake?I had to update 35757s01 subpart to fit eye position. Please download it again!
(2024-01-17, 15:33)Philippe Hurbain Wrote: [ -> ]I had to update 35757s01 subpart to fit eye position. Please download it again!
https://library.ldraw.org/tracker/34005
