2024-01-05, 23:20
2024-01-06, 15:20
Here is raw dat file extracted from Lego instructions app as well as raw graphical assets if it can help for the patterns
2024-01-06, 15:35
(2024-01-05, 23:20)Dario Wrote: [ -> ]Its possibile make the recent lute medieval instrument? 80503pb01
On the tracker without pattern
https://library.ldraw.org/tracker/33826
2024-01-06, 21:18
(2024-01-06, 15:35)Gerald Lasser Wrote: [ -> ]On the tracker without pattern
thanks. im new on the lego designer software... i use Studio... how can i import in Studio?... i try with part designer but seem its not the right way....
lute where recognize from studio part designer but i don able to add the print... can you suggest me something?
2024-01-06, 22:20
(2024-01-06, 21:18)Dario Wrote: [ -> ]thanks. im new on the lego designer software... i use Studio... how can i import in Studio?... i try with part designer but seem its not the right way....
Part designer is the way to do.
1) create some dir structure somewhere on your PC thant looks like:
./parts/
./parts/s
2.) download the individual files of the part and save them as follows:
./parts/80503.dat
./parts/s/80503s01.dat
./parts/s/80503s02.dat
./parts/s/80503s03.dat
3.) go to parts designer
- create new
- from scratch
- import
- select yout /part dir and choose 80503.dat
- chose insert
4.) go to connectivity tab
5) add desired connectivity (Accessories > Clip and > Bar > Bar) position two bars at the neck of the instrument and at the back handles
6.) export to studio
2024-01-06, 22:44
(2024-01-06, 22:20)Gerald Lasser Wrote: [ -> ]Part designer is the way to do.for lute i have problem to add pattern... for falcon i have an error at the import
./parts/
./parts/s
./parts/80503.dat
- create new
- from scratch
- import
- chose insert
2024-01-07, 10:06
1. For the lute pattern:
The images I shared are raw graphical elements that can't be used as is. They need to be reworked before you can apply them as you try to do.
2. For the falcon:
You probably forgot to download 2581s02.dat and put it in ./parts/s/
2. For the falcon:
2024-01-07, 12:47
(2024-01-07, 10:06)Vincent Messenet Wrote: [ -> ]1. For the lute pattern:thanks a lot, im very happy for this part ))
2. For the falcon:
