i have a request for the following pieces to be added
24190 Large Figure Torso Skeletal with Ball Joint and Gear Hips / Waist / Bottom shorturl.at/dHQY2
[attachment=10562]
24189 Large Figure Torso Skeletal Connector with 2 Ball Joint shorturl.at/dgDE5
[attachment=10561]
heres a pic of the bottom of the upper torso piece [
attachment=10599]
i think the gear at the bottom has 14 teeth
i made a rough version of the torso piece in part designer
(2023-12-21, 14:52)notmaster Wrote: [ -> ]i made a rough version of the torso piece in part designer
Your mock-up is to short.
I can't promise anything, but I have started working on these ...
Do you have this part?
attachment=10601][
attachment=10602]
(2023-12-22, 14:05)Magnus Forsberg Wrote: [ -> ]Your mock-up is to short.
unforuntabl;ey no i dont have piece but heres a bunch of refernce images and also the gear at the bottom of the torso piece is different with i think 14 gear teeth
shouldnt the end balls be the bowlball.dat ones? and is the big pin joint the same as the one from the technic wheel hubs?
(2023-12-22, 19:29)Rene Rechthaler Wrote: [ -> ]shouldnt the end balls be the bowlball.dat ones? and is the big pin joint the same as the one from the technic wheel hubs?
yeah the big pin on the pelvis is similar to the one from the technic wheel hubs
similar or same? can they be mixed (both ways)?
and for the "pelvis": is that a double length pinhole? with middle stop for pins? as far as I can see from the sets using it, its supposed to be used with a 12T bevel gear
--> if the partial gear from the top is a 20T gear, are the teeth aligned or shifted one half tooth to be inline with the bevel?
maybe it has the shape and functionality of a 20T Bevel, but it seems that the 2 side groups of 3 are merged into one so it actually has only 14 usable teeth...
