2023-07-15, 14:12
you can import STL files into LDPE now (binary and ASCII STL).
And thanks to Willy's and Magnus' feedback I fixed two errors.
One solution improves the speed for the change of the line size alot.
The other solution corrects the detection on invalid "0 BFC INVERTNEXT" meta statements.
Changelog:
(1 new feature and 2 bug fixes)
The following critical issue is fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...import STL files (via "Open Part File" -> choose "STL-File (*.stl)", instead of "LDraw Source File (*.dat)").
- Switching the line size caused long reloading times.
- "BFC INVERTNEXT" was invalid when the previous subfile was not found.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.69.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.69-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.69.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
