2022-07-02, 14:14
Hey,
this is mostly a small bugfix release, but it includes also a shortkey binding to rotate the view around a fixed axis with the mouse.
![[Image: attachment.php?aid=12753]](https://forums.ldraw.org/attachment.php?aid=12753)
Changelog:
(1 new feature and 3 bug fixes)
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...press and hold shortkeys to rotate the view around a fixed axis with the mouse (snapping to angles, with Shift, Ctrl and Alt).
- The check for BFC-Meta command was not strict enough (it allowed prefix lines like "0 BFC CERTIFY CCWxyz").
- !HISTORY meta command: Removed the [4.0] tag in favor of a fixed implementation date.
- Added missing buttons on the UI for area expansion / missing buttons on "Find+Replace" dialog.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.58.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.58-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.58.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
