2021-11-29, 5:53
i import a lego set in ldcad.But the partsquantity will not decrease ,just like [attachment=7151]pattle in stud.io。I am not used to using studio,It's not convenient for MOC
(2021-11-29, 5:53)HWQ Wrote: [ -> ]i import a lego set in ldcad.But the partsquantity will not decrease ,just like pattle in stud.io。I am not used to using studio,It's not convenient for MOC
(2021-11-29, 8:45)Philippe Hurbain Wrote: [ -> ]That's a long sought after feature missing from LDCadIt is a planned 1.7 feature, it will probably be in Beta 1 (I'm almost done with Alfa 2 which mostly concentrates on animation stuff)..
(2021-11-29, 8:45)Philippe Hurbain Wrote: [ -> ]One thing you can do is to quickly check the inventory of your model: Script -> Samples -> Generate BOM list.There is also the special bin group "All parts in model", which shows the current number of used parts.
(2021-11-29, 20:19)Roland Melkert Wrote: [ -> ]It is a planned 1.7 feature, it will probably be in Beta 1 (I'm almost done with Alfa 2 which mostly concentrates on animation stuff).
If needed you can also export that list to csv using the bin export option.
(2021-12-02, 3:37)HWQ Wrote: [ -> ]When will we officially release version 1.7(With this function...)
I am not used to using studio,its sad for me.....
(2021-12-02, 20:18)Roland Melkert Wrote: [ -> ]I'm hoping to finish Alpha 2 in my upcoming Christmas vacation.
I will look into adding the feature to Alpha 2, but only if it's doable without too much hassle.
A Beta 1 (or Alpha 3) will follow in early 2022.
(2021-12-02, 20:18)Roland Melkert Wrote: [ -> ]我希望在即将到来的圣诞假期中完成 Alpha 2。EMMM When will the new version be released
我会考虑将该功能添加到 Alpha 2 中,但前提是它可以在没有太多麻烦的情况下实现。
Beta 1(或 Alpha 3)将于 2022 年初推出。
(2022-03-04, 0:47)HWQ Wrote: [ -> ]EMMM When will the new version be released
