2021-10-02, 10:04
Hi all,
I started using LPub3D and would like to ask for help with camera pan / zoom /position configuration.
The model is designed with LDCad, the camera angles are set by Ctrl+B and double checked with B keyboard shortcut. Opening the model with LPub3D shows the correct camera angles. As far as I understand, the LDCad camera pan / zoom / position is not saved (ROTSTEP is used which stores only angles). So I tried to adjust the camera pan / zoom / position in the Visual Editor, but I can't get LPub3D to use this setting for the instruction (I only found the "Apply ROTSTEP" button which does not help as the angles are already ok). Please see the attached image.
Thank you very much for any help or hint.
Best regards
Stefan
Best regards
Stefan
