2020-07-24, 22:33
Please vote on the following two sets of changes. Note: a single vote for or against both sets of changes, since the two are related.
!TEXMAP spec (changes highlighted in red):
https://www.ldraw.org/draft-texmap.html
[color=#333333][size=small]Official Library spec:
Under [color=#0072bc]META Commands add:
!TEXMAP Meta
Sufficient !TEXMAP <geometry2> and/or <geometry3> lines (as outlined in the Texture Mapping (!TEXMAP) Language Extension) must be included such that the part renders correctly in non-!TEXMAP supporting programs. It is highly encouraged that the included geometry reflect the pattern created by the !TEXMAP, even if it is reduced in resolution or colors, but this is not required.[/color][/size][/color]
!TEXMAP Meta
