Full Version: Star Wars 2020
Pages: 1 2
(2020-05-26, 7:13)Jaco van der Molen Wrote: [ -> ]Missing air tubes. Any ideas on how to model those?
Looks like that's made with these train wheels:
https://www.ldraw.org/parts/official-par...rtid=50254
You could devise an LDCad template using these as donor parts, I should think.
(2020-05-26, 15:50)N. W. Perry Wrote: [ -> ]Looks like that's made with these train wheels:
Yah, definitely could do this with LDCad flex objects. I'll see what I can gen up if someone else doesn't beat me to it.
(2020-05-26, 7:12)Jaco van der Molen Wrote: [ -> ]OMR compliant? MPDCenter says not, but I cannot resolve the problems it reports.
Can someone take a look?
First thing needed to do was add the "LDRAW_ORG Model" line to all subfiles. After changing the main file with the header dialog, MPDCenter offered to automatically change the rest as well.
Next, some file titles (description) don't match the Name line (they list multiple step numbers, for example). This was most easily fixed in LDCad with Clean Up…sync name and sync description.
One file had an incorrect header sequence, and another had an unofficial part needing to be added. (LDCad's Clean Up could have handled this as well, but I did them separately.)
After adding the unofficial part, it and its subfiles just needed to be renamed for OMR conformity. Again, LDCad's Clean Up works (first remove set number prefixes, then re-add them to everything, otherwise you'll get double prefixes for those files that were already correct).
The resulting file passes OMR check and is attached (after fixing the filename to .mpd and deleting duplicate licenses in two subfiles—both of which were caught by LDInspector but not by MPDCenter):
[attachment=5310]
(2020-05-26, 17:19)N. W. Perry Wrote: [ -> ]First thing needed to do was add the "LDRAW_ORG Model" line to all subfiles. After changing the main file with the header dialog, MPDCenter offered to automatically change the rest as well.
OK, tnx Perry!
Where can I find Clean Up… sync name and sync description in LDCad?
(2020-05-27, 17:24)Jaco van der Molen Wrote: [ -> ]OK, tnx Perry!
Clean Up is in the File menu.
(2020-05-27, 18:18)Orion Pobursky Wrote: [ -> ]Clean Up is in the File menu.
Oh dear, never knew about its existence  Blush Big Grin
75272 - Sith TIE Fighter
[attachment=5526]
OMR Compliant
Missing: 2 patterned parts and Minifigs
77904 -  Nebulon-B Frigate
[attachment=5890]
OMR Compliant
Missing: Sticker
Pages: 1 2
