2020-01-08, 21:30
Since we use a hybrid threaded model, I’m toying with turning off automatic quoting. This mean that the post you are replying to won’t be quoted unless you explicitly check the quote box next to the post.
Thoughts?
Thoughts?
(2020-01-08, 21:30)Orion Pobursky Wrote: [ -> ]Since we use a hybrid threaded model, I’m toying with turning off automatic quoting. This mean that the post you are replying to won’t be quoted unless you explicitly check the quote box next to the post.
Thoughts?
(2020-01-09, 2:02)Travis Cobbs Wrote: [ -> ]Right now, it quotes the message I am replying to, whether or not I hit the "Quote" button first. So, when the quote button has a green plus, it quotes, and when it has a red minus, it quotes. Are you proposing to make that button actually function, and have quotes off by default?
(2020-01-09, 3:02)Orion Pobursky Wrote: [ -> ]The quote button is for multi-quoting. You click the posts you want to quote and it auto-inserts them into your post. With reply, only the post you are replying to get quoted.
(2020-01-09, 18:41)Travis Cobbs Wrote: [ -> ]Wow. That's not at all intuitive, but potentially very useful. Thanks for explaining it.
So, for your proposal, are you proposing that if you don't click this quote button on the post you are replying to, there will be no quote? And clicking that button on the one post will make it behave as it does now when you don't click it anywhere?
(2020-01-10, 0:38)Travis Cobbs Wrote: [ -> ]I'm ok with the change.So am I...
