Hi there,
this time it's the 1988's Test Car Technic model 8865. It should be OMR compliant, but there are known issues:
- Small mismatch for 16-technic-brick (3703) which connects the front frame to the roof in the last step. As far as I can see and calculate with CAD, this seems to be "desired margin" in the real build. Did I something wrong, is there a way to make it look "better matching"?
- The steering axle angles with two universal joint (2x 3712+3326b+3712) in steps 16/17 are not acceptable. I looked at the angles provided by "Selection Info" without luck - I will fix this as soon as possible and would welcome any suggestion.
Done with LDCad 1.6c (Linux64).
Thanks in advance for any improvement suggestion!
Regards
Stefan
(2019-11-27, 21:27)Stefan Frenz Wrote: [ -> ]Hi there,
Regards
Stefan
The “mismatch” you refer to is exactly the scenario that prompted me to post
this thread.
And in my own 8865 model, the u-joint issue was handled using the advice given in
this thread—which was inspired by my efforts to build the original Auto Chassis.
(2019-11-28, 4:31)N. W. Perry Wrote: [ -> ]The “mismatch” you refer to is exactly the scenario that prompted me to post this thread.
And in my own 8865 model, the u-joint issue was handled using the advice given in this thread—which was inspired by my efforts to build the original Auto Chassis.
Thank you so much, this was exactly what I was looking for.
I will update my model accordingly.
Now done and updated, thank you very much.
Remaining known issues: none
Regards - Stefan
(2019-11-28, 8:40)Stefan Frenz Wrote: [ -> ]Now done and updated, thank you very much.
Regards - Stefan
Hi Stefan
Following Problem:
There is a Part (submodell) missing:
Johann
(2019-12-26, 21:11)Johann Eisner Wrote: [ -> ]Following Problem:
Hi Johann,
thank you very much, attached is an updated version - the missing part was intentionally deleted because it was empty. I missed to delete the part ref...
Best regards
Stefan
