2019-10-08, 18:10
Hey,
this is a critical hotfix release for yesterday's release of version 0.8.49. It was not possible to open a *.dat file with the open file dialog.
Changelog:
(1 bug fix)
The following critical issue is fixed:
What will the next release 0.8.50 deliver? clever auto-completion / context menu for the text editor / usability.
System Requirements:
Minimum System Requirements:
Changelog:
(1 bug fix)
- It was not possible to open a part file via the 'Open Part File' buttons : A "\" character was missing between the folder name and the file name.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 versionIf it's not a 64-bit version, you'll get a message that looks like:
