Full Version: 3D Part Preview added to Parts Tracker
(2019-09-08, 15:31)Magnus Forsberg Wrote: [ -> ]The 3D part preview seem to be case sensitive.
I made three new files, 3815bpw1c01 - 3815bpw3c01.
They all had code like this:
1 16 0 0 0 1 0 0 0 1 0 0 0 1 3815b.DAT
1 16 0 12 0 1 0 0 0 1 0 0 0 1 3816bpw3.DAT
1 16 0 12 0 1 0 0 0 1 0 0 0 1 3817bpw3.DAT
None of them showed up in the 3D viewer.
Then I changed two files: 3815bpw1c01 - 3815bpw2c01
1 1 0 0 0 1 0 0 0 1 0 0 0 1 3815b.dat
1 16 0 12 0 1 0 0 0 1 0 0 0 1 3816bpw2.dat
1 16 0 12 0 1 0 0 0 1 0 0 0 1 3817bpw2.dat
and now they are visible in the 3D viewer.
I left the third file 3815bpw3c01 unchanged.
The server is case sensitive so I probably just need to lower case my url search code.
Should be fixed now.
It looks like something is wrong in the viewer. The random colour button also randomize some of the vertices and break the model geometry.
(2019-09-09, 9:15)Magnus Forsberg Wrote: [ -> ]It looks like something is wrong in the viewer. The random colour button also randomize some of the vertices and break the model geometry.
That sounds bad. Do you have a sample file where this is observed?
(2019-09-09, 10:01)Lasse Deleuran Wrote: [ -> ]That sounds bad. Do you have a sample file where this is observed?
I've seen it on two different pc's, on two different parts, 44301a.dat and 93575.dat. These are recently updated parts on the PT.
Can confirm. Just use any part on the tracker. The more triangles, the better.
(2019-09-09, 11:55)Magnus Forsberg Wrote: [ -> ]I've seen it on two different pc's, on two different parts, 44301a.dat and 93575.dat. These are recently updated parts on the PT.
Here too. Especially impressive for https://www.ldraw.org/cgi-bin/ptdetail.c.../u9479.dat
Excellent. Thanks. I see it now too. I will make a local copy and start debugging this evening.
Edit: It seems to be due to poor vertex attribute construction. Unfortunately the bug only appears intermittendly once I reduce the input :S
[.WebGL-0x7fbd710dd000]GL ERROR :GL_INVALID_OPERATION : glDrawElements: attempt to access out of range vertices in attribute 0
Bug identified and fixed in latest push to master branch.
I made the mistake of using the same markers for line vertices and triangle vertices, resulting in triangle vertices being marked as already being in use when they were not. This sometimes resulted in fancy gradient colors, and sometimes complete failures of texture loading.
Thanks for the bus report. This error would otherwise have affected all multi-colored parts.
(2019-09-09, 21:22)Lasse Deleuran Wrote: [ -> ]Bug identified and fixed in latest push to master branch.
Update pulled to server. Everything appears to be fixed.
