(2019-06-16, 4:31)Chris Dee Wrote: [ -> ]Go ahead. Could the non-BFC column be removed, as we expect everything tpo be BFC these days?
I have removed the non-BFC column, but not checked for compatibility with the new agreement.
(2019-06-24, 7:34)Santeri Piippo Wrote: [ -> ]"Filename ending does not match declared LDRAW_ORG file type.": what does this mean? How do filename endings correlate with LDRAW_ORG file type? I guess subfiles have 's01' and so on but other than that I don't really get it.
"Filename ending does not match declared LDRAW_ORG part type qualifier." likewise...?
I think this means the file is .ldr instead of .dat when LDRAW_ORG indicates it's a part.
(2019-06-24, 7:34)Santeri Piippo Wrote: [ -> ]"Wrong BFC command found." What is a wrong BFC command?
Illegal combination of meta keywords.
(2019-06-24, 7:34)Santeri Piippo Wrote: [ -> ]"T-Junction detected." T-junction detection can be very difficult to implement and only a small minority of T-junctions are actual problems. Do we really want to automate this?
T-Junctions can cause seams during rendering so I would prefer them gone
Detecting them could be done by checking if vertices are near triangle/quad side lines without being part of that polygon.
This might need to include full recursive mesh data so it can check on the assembled part level.
(2019-06-24, 17:39)Roland Melkert Wrote: [ -> ]T-Junctions can cause seams during rendering so I would prefer them gone
May I say I don't agree (at all!!!)? Most so called T-junctions never produce artifacts and can significantly reduce the number of faces to render!!!
(2019-06-24, 7:34)Santeri Piippo Wrote: [ -> ]"HELP entry length":
It should trigger a warning because of readability. If this text would end up in just one line it get's harder reading it
(2019-06-25, 6:45)Philippe Hurbain Wrote: [ -> ]May I say I don't agree (at all!!!)? Most so called T-junctions never produce artifacts and can significantly reduce the number of faces to render!!!
It partly depends on the size of the polygons but it can really cause seams due to rounding errors.
This because the rasterizer doesn't guarantee the calculated final position of the projected vertex is (still) exactly on the companion polygon's side. This can cause a single pixel offset resulting in a seam.
See also:
https://computergraphics.stackexchange.c...-in-cracks
It can also upset normal calculations, because weird jumps in smoothness could occur if the two t-juncted polygons aren't on the same plane.
(2019-06-25, 17:24)Roland Melkert Wrote: [ -> ]It partly depends on the size of the polygons but it can really cause seams due to rounding errors.
See also:
Ok, but take this part for example:
https://www.ldraw.org/cgi-bin/ptdetail.c...004p0d.dat
If I got rid of T-Junctions, there would a huge amount of small, thin triangles around the border.
(2019-06-25, 17:55)Orion Pobursky Wrote: [ -> ]Ok, but take this part for example:
That part doesn't seem to suffer from the problem indeed, but it has only 4 quads introducing t-junctions (the side frame).
So it would only need 14+14+4+4=36 extra quads to be completely t-junction free.
But in the end it's all on a very small surface so you might be right about it not be 'worth' it for such parts.
See also:
I know the rationale behind that, I just say that if you SEE no problem, then there IS no problem having T-junctions. And actually it's fairly rare you see artifacts (at least in planar surfaces)
(2019-06-25, 18:36)Philippe Hurbain Wrote: [ -> ]I know the rationale behind that, I just say that if you SEE no problem, then there IS no problem having T-junctions. And actually it's fairly rare you see artifacts (at least in planar surfaces)
This is actually my philosophy for almost the entire HOLD list: an unnoticed error is not an error. I reiterated it several times when we were discussing it.
(2019-06-25, 18:28)Roland Melkert Wrote: [ -> ]That part doesn't seem to suffer from the problem indeed, but it has only 4 quads introducing t-junctions (the side frame).
Actually, the T-Junctions in that part
do produce visible artifacts (at least in LDView on some hardware):
At many viewing angles, there are no artifacts, and I had to very slowly rotate to get to a viewpoint where three were visible at once, but at least one was commonly visible.
As I point out above, the problem exists. Granted, my screenshot was an unusual situation, where the part is zoomed in quite far, but since the artifacts on T-junctions are pseudo-random, they scale based on the total number of pixels that are in the scene that happen to lay on a boundary where T-junctions exist. So, if the above part were used repeatedly in a scene, but each one were quite small in the view, it's still likely that the T-junctions would lead to a similar number of incorrectly colored pixels. On average, the number of incorrectly colored pixels might be less than 1 (so none visible in many frames), but they would flicker into existence during animation.
(2019-06-25, 18:52)Orion Pobursky Wrote: [ -> ]This is actually my philosophy for almost the entire HOLD list: an unnoticed error is not an error. I reiterated it several times when we were discussing it.
Heartfully, isotropically and continuously agree!
(2019-06-25, 20:44)Travis Cobbs Wrote: [ -> ]As I point out above, the problem exists.
Yes it does but...
Quote:Granted, my screenshot was an unusual situation,
...add in some antialiasing, and it becomes next to impossible to see, even in this pathological view case!
(2019-06-26, 6:30)Philippe Hurbain Wrote: [ -> ]Yes it does but...
Just to clarify, I don't feel that T-junctions should trigger a hold. However, I do feel that every effort should be made to avoid them (even in the example given).
(2019-06-24, 7:34)Santeri Piippo Wrote: [ -> ]I had some time to work on the checking tool and I put up a new version up at the usual location,
Teemu,
any idea how this can be integrate into ldraw.org o is a link in the PT Tools enough?
(2019-06-25, 8:14)Willy Tschager Wrote: [ -> ][*]
0 BFC CERTIFY INVERTNEXT
There's a separate entry in the issue list for "CERTIFY INVERTNEXT".
(2019-06-25, 8:21)Willy Tschager Wrote: [ -> ][*][*]
I guess that makes sense since it reads so in the spec...
(2019-06-26, 18:16)Travis Cobbs Wrote: [ -> ][*][*][*]
In any case I don't think that I'm going to implement automatic T-junction detection since it seems to vary case-by-case whether it's a problem or not.
(2019-06-27, 6:46)Willy Tschager Wrote: [ -> ][*][*][*][*]
Teemu,
I understood that the idea was to integrate this to the parts tracker. It can be run from the command line so I think hooking it up shouldn't be such a problem. I can also put together some other interface if that is needed.
(2019-06-28, 8:12)Santeri Piippo Wrote: [ -> ]I understood that the idea was to integrate this to the parts tracker. It can be run from the command line so I think hooking it up shouldn't be such a problem. I can also put together some other interface if that is needed.
What language is it written in? Does it run on Linux?
(2019-06-28, 9:09)Chris Dee Wrote: [ -> ]What language is it written in? Does it run on Linux?
It is written in Python 3, so it runs on Linux.
(2019-06-24, 7:34)Santeri Piippo Wrote: [ -> ]I had some time to work on the checking tool and I put up a new version up at the usual location, roughly doubling the amount of detected issue types. I've attached here a table of the current implementation status of the tool:
Just made a few tries, like the speed of your tool!
Problems I found so far:
- The file name is not checked against header name field
- Got "Line 139: hairline polygon (smallest angle 0.24°) — WARNING" while hairline threshold is 0.025°
- There is currently a problem with the new parts update, checker complains about missing files included in the last update.
(2019-06-28, 13:48)Philippe Hurbain Wrote: [ -> ]Just made a few tries, like the speed of your tool!
Can we spit discussion about Santeri’s checker out into a new thread?
