Hi all,
For quite some time now I was wondering why these parts do not show up in the Plate category part bin in LDCad:
14418 Plate 1 x 2 with Socket Joint-8 with Friction
14419 Plate 1 x 2 with Socket Joint-8 with Friction and Ball Joint-8
14704 Plate 1 x 2 with Socket Joint-8 with Friction Centre
It turns out these are located in the "Hinge plates and tiles" part bin.
Their counterparts like 14417 Plate 1 x 2 with Ball Joint-8 on Side and 22890 Plate 1 x 2 with Ball Joint-8 on End do show up in the Plates bin.
So either all go to "Plates" or all go to "Hinge Plates"
Can somebody either confirm, agree, disagree or clarify?
Thanks.
Jaco
Confirmed, it's a mess. 14418, 14419 and 14704 carry an explicit hinge category, while 14417 and 22890 do not, thus fall in their default plate category because of description.
(2019-06-04, 10:54)Jaco van der Molen Wrote: [ -> ]It turns out these are located in the "Hinge plates and tiles" part bin.
The normal plate bin has been bothering me for awhile now, it's getting way too crowded in there.
Maybe I should force all the balljoint stuff into the hinge plate group ?
A quick remodel:
<rules>
include category plate
exclude description ~*,_*,=*
exclude description duplo
exclude keyword wing
exclude description without corner,joint,hinge,hinges,towball
for platesNormal.pgg
and
<rules>
include all
keep partName 313.dat
exclude !category hinge,plate
exclude description brick,panel
exclude !description hinge,hinges,joint,ball,car roof,towball
for platesHinges.pbg
(2019-06-04, 18:50)Roland Melkert Wrote: [ -> ]The normal plate bin has been bothering me for awhile now, it's getting way too crowded in there.
A quick remodel:
<rules>
and
<rules>
include all
OK, that is one solution. I'll try that.
The other one is to take care of descriptions and keywords in the parts themselves because that is also not quite right.
We are planning to do that too.
(2019-06-04, 21:10)Jaco van der Molen Wrote: [ -> ]OK, that is one solution. I'll try that.
OK, thanks Roland. Modifying the pbg files helps. We might need to overlook and rework more categories like this.
I remember now altering the on for plain tiles and excluding the "without groove" from the bin, by adding "without groove" to the exclude description in tilesPlain.pbg
(2019-06-05, 5:59)Jaco van der Molen Wrote: [ -> ]I remember now altering the on for plain tiles and excluding the "without groove" from the bin, by adding "without groove" to the exclude description in tilesPlain.pbg
You mean the above "without corner"?
I excluded those plates because I consider them wing parts, which have there own group.
(2019-06-05, 17:18)Roland Melkert Wrote: [ -> ]You mean the above "without corner"?
No, I mean without groove (for tiles) to be sure I do not use a tile without groove by mistake.
