Attached is a snippet of an official model I am working on.
The steering arms (2739a) and the steering links (6540b) should match up with the arms at 90 degrees. I'm posting this to see if this is a problem with one of the parts or if I'm doing something wrong.
(2019-03-07, 18:18)Orion Pobursky Wrote: [ -> ]Attached is a snippet of an official model I am working on.
My bet is that 6540b is slighly off. (6540a is the same). Distance in z direction between towball and pinhole is 22 ldu, I guess it should be 20ldu.
(2019-03-07, 18:47)Philippe Hurbain Wrote: [ -> ]My bet is that 6540b is slighly off. (6540a is the same). Distance in z direction between towball and pinhole is 22 ldu, I guess it should be 20ldu.
I don't have this part but it's pretty cheap so I can order it.
(2019-03-07, 18:57)Orion Pobursky Wrote: [ -> ]I don't have this part but it's pretty cheap so I can order it.
Just checked, got it! I'll measure tomorrow !
(2019-03-07, 20:45)Philippe Hurbain Wrote: [ -> ]Just checked, got it! I'll measure tomorrow !
I just ordered both versions so I can double check you.
I came to the same conclusion. Something is off by 2 ldu. It could be either the pin/axle hole or the towballs.
(2019-03-07, 22:21)Magnus Forsberg Wrote: [ -> ]I came to the same conclusion. Something is off by 2 ldu. It could be either the pin/axle hole or the towballs.
Clearly distance should be 20 x 70 ldu, not 22 x 70!
https://photos.app.goo.gl/WEAjRxRjqAWTaJwRA
Position of towballs vs. ring are OK. I'll correct...
