Hi all,
Can someone please help me to create the basics for 2 texture mapped parts?
I am still a bit unsure how to do that with irregular shapes.
I need to texture map these parts, both white.
Tile, Modified 2 x 3 Pentagonal / FLAT TILE 2X3 W/ ANGLE
![[Image: 6245249]](https://www.lego.com/service/bricks/5/2/6245249)
What part number for this is best to use? 22385, 35341 or 35339?
The print is only on the square part (not in the point)
And part 13459:
LegoRoad Sign Round on Pole / ROUND SIGN 1X5X3
The sign: one on one side and one both sides :-)
Pattern print on the round piece of course.
Do the PNG files need to be rectangularly shaped with white or transparent background?
Help is much appreciated.
Jaco
A few examples attached...
(2019-01-30, 10:05)Jaco van der Molen Wrote: [ -> ]And part 13459:
This one is not subparted (it's clearly made for stickers), so I had to subpart it...
Made only a double sided one. For a single sided, remove the texmap stuff of one section, leave only the content of fallback.
Quote:Do the PNG files need to be rectangularly shaped with white or transparent background?
Doesn't matter if it is outside the surface onto which it is applied. Note that I left a transparent window in the image to let the color of the part see through.
(2019-01-30, 14:08)Philippe Hurbain Wrote: [ -> ]A few examples attached...
Ah, OK, I see. Many thanks.
I will study these parts.
As for the part number of the nexo shield tile part and its aliases: does it really matter what part I use?
I think this probably has something to do with solid plastic and color and transparent ones?
(2019-01-30, 14:38)Jaco van der Molen Wrote: [ -> ]As for the part number of the nexo shield tile part and its aliases: does it really matter what part I use?
As seen on brickset, 35339 is the trans clear version. Dunno the difference (if any) between 22385 and 35341. Anyway, only 22385 exist as LDraw part...
(2019-01-30, 14:57)Philippe Hurbain Wrote: [ -> ] (2019-01-30, 14:38)Jaco van der Molen Wrote: [ -> ]As for the part number of the nexo shield tile part and its aliases: does it really matter what part I use?
Hi
If you use the 22385 part, then the numbering according to standard for printed parts.
Only the Nexo Knight Power shields use 3 digits.
https://forums.ldraw.org/thread-22777-po...l#pid28429
Regards Johann
(2019-01-30, 17:07)Johann Eisner Wrote: [ -> ] (2019-01-30, 14:57)Philippe Hurbain Wrote: [ -> ]As seen on brickset, 35339 is the trans clear version. Dunno the difference (if any) between 22385 and 35341. Anyway, only 22385 exist as LDraw part...
Hi
Regards Johann
Thanks for pointing that out.
But since my part is custom and won't need to become official or submitted to the PT, I'll stick with 22385 ;-)
