2018-12-28, 3:53
2018-12-28, 8:00
(2018-12-28, 3:53)Shi.Yan Wrote: [ -> ]How did universal Joint edit in LDCAD,In order to flex a universal joint, you need to break it to its ends and centre components.
- Use these components directly (parts 62519 / 62520)
- or place the shortcut 61903 and "inline it" (break it into components): Select it -> right click -> reorganize -> inline.
2018-12-28, 9:17
(2018-12-28, 8:00)Philippe Hurbain Wrote: [ -> ](2018-12-28, 3:53)Shi.Yan Wrote: [ -> ]How did universal Joint edit in LDCAD,In order to flex a universal joint, you need to break it to its ends and centre components.
thank you Very much,great help
2018-12-30, 1:29
(2018-12-28, 9:17)Shi.Yan Wrote: [ -> ](2018-12-28, 8:00)Philippe Hurbain Wrote: [ -> ]In order to flex a universal joint, you need to break it to its ends and centre components.
[attachment=3357]
How to change angle to connect two joints
2018-12-30, 9:02
Quote:How to change angle to connect two jointsThe rotate pin, even in finest grid, can't go lower than 1°. So to get precise rotation you need to use the manual rotate tool where you are able to key in the rotation angle (toolbar round arrow, shortcut ctrl+r). Remember that you can put the angle value given by the measure tool sinply by clicking in the value box.
For more details, see the advanced editing tutorial, shock absorber section at bottom: http://www.melkert.net/LDCad/docs/advEdit
2018-12-31, 1:31
(2018-12-30, 9:02)Philippe Hurbain Wrote: [ -> ]Quote:How to change angle to connect two jointsThe rotate pin, even in finest grid, can't go lower than 1°. So to get precise rotation you need to use the manual rotate tool where you are able to key in the rotation angle (toolbar round arrow, shortcut ctrl+r). Remember that you can put the angle value given by the measure tool sinply by clicking in the value box.
I had read it carefully,but i wish know more detail about it .
Help document content is too small :-(
2018-12-31, 5:45
I had finished it. Thanks a lot.
next to do animate.
2018-12-31, 9:15
(2018-12-31, 5:45)Shi.Yan Wrote: [ -> ]next to do animate.That's another story... good luck
