Hi Roland, and others,
I have LDCad 1.6b running and configured like it should, but no texture is rendered on textured parts.
I still have LDCad 1.6a running on the same machine that uses the same libraries and there all my custom texturemapped parts render just fine.
What could be wrong?
I obviously checked and made sure Texture mapping was enabled in 1.6b.
(2018-05-17, 13:15)Jaco van der Molen Wrote: [ -> ]I have LDCad 1.6b running and configured like it should, but no texture is rendered on textured parts.
The only thing changed regarding textures between a and b is generation of mipmaps. So this could be a driver thing.
Did you use the same main.cfg for both versions? You can force that by (tmp, rename the a version exe) placing the b version in the a version's bin folder.
(2018-05-17, 16:50)Roland Melkert Wrote: [ -> ] (2018-05-17, 13:15)Jaco van der Molen Wrote: [ -> ]I have LDCad 1.6b running and configured like it should, but no texture is rendered on textured parts.
Hmm, OK. I did not use the same main.cfg because I have set up 1.6b like a fresh install.
I did make a copy of the LDCad.exe for 1.6b and placed that in the 1.6a folder (after backing up the original indeed ;-)
That did the trick. Textures render fine!
Now what causes that?
The only true difference (besides window state, last openend files, etc) between the two setups I could find was in the main.cfg [LDraw] section
vertexProcessingMode=smooth (1.6a)
vertexProcessingMode=none (1.6b)
Setting it to smooth in 1.6b did the trick in the 1.6b setup. It now renders textures fine too... ;-)
(2018-05-18, 5:57)Jaco van der Molen Wrote: [ -> ]The only true difference (besides window state, last openend files, etc) between the two setups I could find was in the main.cfg [LDraw] section
Ah I forgot that restriction, the none mode does zero post processing on the LDraw xyz coordinates, this includes generating the uv parameters.
