I just stumbled across this when working on the new bull-bar (35654)
The Tile of part 15712 is 0,5 LDU thinner than the Tile of part 12825.
Did anybody notice this yet? Could not find anything through the search.
(2017-12-28, 22:00)Gerald Lasser Wrote: [ -> ]Did anybody notice this yet? Could not find anything through the search.
As being the author of 15712, no. How does it differ? I don't understand.
(2017-12-28, 22:43)Magnus Forsberg Wrote: [ -> ]As being the author of 15712, no. How does it differ? I don't understand.
The surface, which is currently at Y=0, is in real life at Y=0.5
I made a mock up for the part I wanted to author and built a holder with the clips from real parts. It struck me that I had quite a big gap with the real thing where there was non in the digital parts.
You barely notice it when you place them in a MOC, but using them as a 'measuring instrument' you notice the difference between the old and the new part.
My calipers tell me the old one is 3.2 mm whereas the new one is just 3 mm. I need to check more of them tomorrow.
(2017-12-28, 23:00)Gerald Lasser Wrote: [ -> ] (2017-12-28, 22:43)Magnus Forsberg Wrote: [ -> ]As being the author of 15712, no. How does it differ? I don't understand.
I took about 10 pieces and they are all 0,2 mm thinner than the old part. Is it worth to change?
(2017-12-29, 12:56)Gerald Lasser Wrote: [ -> ]they are all 0,2 mm thinner than the old part. Is it worth to change?
Yes, I can confirm that measurement.
Usually we don't bother dealing with design differencies smaller that 1ldu, but in this case I think we should.
The lower top surface makes it possible to rotate anything attached to the clip a further 2.73 degrees.
