2016-08-06, 17:05
Hi all,
I've released LDCad 1.6 Alpha 4.
As always some new things in this one:
Mirroring
This works out of the box on most parts assuming those parts are symmetrical in the X direction or not symmetrical at all. Parts having a left and right version will also usually work out of the box as the feature uses the 'left' / 'right' phrases in descriptions to locate the counter part. All other parts will need shadow information to tell the feature how to mirror and or what the counter part is. I added this information for the technic panels and some technic pins. I will add more during the beta stage. Any help on this is also appreciated
(MPD/OMR) file cleanup
This is a generic fle clean dialog which lets you handle things like prefixes, removal of unused submodels and part embedding etc
Layered grouping (EXPERIMENTAL)
Quick and dirty implementation of layering. This allows for the different group configurations of overlapping content. You can also use it to temporary disable grouping to work with the loose items without having to ungroup first.
Redirection removal
This will replace ~moved to, alias and coloured parts in the selection with their final destinations.
And many bugfixes and small tweaks.
Like usual.
This will probably be the last Alpha version as only two major things are remaining.
I think this is the most stable Alpha so far, it might even be on par with 1.5 but please realize this is still a test version so it might be (very) unstable use it separate from your normal LDCad installation and make backups of the files you want to edit.
Download it here:
http://www.melkert.net/LDCad/nextVer
As always any and all feedback is welcome.
Mirroring
Redirection removal
Like usual.
Download it here:
