Gerald's Parts and Pieces Thread - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Gerald's Parts and Pieces Thread (/thread-18039.html) Pages:
1
2
RE: 20455 Gyrosphere Part - Gerald Lasser - 2019-06-06 (2019-06-06, 9:53)Philippe Hurbain Wrote: Yuck... Can you share the files? Only late evening, I started a render on my laptop which turned out to use more energy than anticipated... I will also try with other transparent parts that consist of sub parts. RE: Gerald's Parts and Pieces Thread - Gerald Lasser - 2019-06-06 Here are the files, I checked if I may have set the wrong part-type, but all are sub-parts... I just tried to render 10312, the big bubble canopy which I did as well and I split also the top surface into four. I get the same seams... I tried to inline the part and the result got worse: A last try was to have the original generated from the CSG tool and take it "as is" (plus cond-lines), that looked quite perfect: Dou you think it has to do with the quad winding when the sub-part is inserted and mirrored? That is the only thing I can imagine RE: Gerald's Parts and Pieces Thread - Roland Melkert - 2019-06-06 (2019-06-06, 20:58)Gerald Lasser Wrote: Dou you think it has to do with the quad winding when the sub-part is inserted and mirrored? That is the only thing I can imagine I think it might has something to do with Z-Sorting as the seems are visible in LDCad too, caused by 'double' alpha blending of certain polygons. LDCad does part level z-sorting, while LDView does polygon level sorting hence no seam. Don't know how that leaks into ray tracing though, as I thought Z-Sorting was a rasterizer specific thing. RE: Gerald's Parts and Pieces Thread - Orion Pobursky - 2019-06-06 (2019-06-06, 22:08)Roland Melkert Wrote: I think it might has something to do with Z-Sorting as the seems are visible in LDCad too, caused by 'double' alpha blending of certain polygons. Studio does rendering with the GPU, not ray tracing. RE: Gerald's Parts and Pieces Thread - Philippe Hurbain - 2019-06-07 Weird problem. Looks as if subparts (or primitives!) are somehow rendered separately. I think you made a wrong manipulation for inlining, here it works perfectly. In the following image, left is a triangle soup (deep inlining), middle uses 1-8sphe primitives, right uses 4 subparts with inner/outer skin. Studio POV render looks good: RE: Gerald's Parts and Pieces Thread - Gerald Lasser - 2019-06-07 Thansk Philo for your experiments! It is a pity that eyesight is doing it like this. Can we ask BL/Stud.io team to look into this or talk to Eyesight? Shall we just open a thread in the forum over there? A lot of the bubble canopies are using the approach of having the surface cut. RE: Gerald's Parts and Pieces Thread - Philippe Hurbain - 2019-06-07 (2019-06-07, 12:10)Gerald Lasser Wrote: It is a pity that eyesight is doing it like this. Can we ask BL/Stud.io team to look into this or talk to Eyesight? Shall we just open a thread in the forum over there?Yes I think it could be a good idea to tell about the problem on Studio forum. But it's kind of hard to get attention there: eg. the shortcut rendering problem reported by several people (including myself!) didn't get any feedback (maybe I missed an answer, anyway the issue is still there). This problem is imho even more annoying, see https://forums.ldraw.org/thread-22940-post-29473.html#pid29473. Corrected image by inlining here: https://forums.ldraw.org/thread-22940-post-29486.html#pid29486 RE: Gerald's Parts and Pieces Thread - Gerald Lasser - 2019-07-02 I have completed two more crazy prints... Cleaning in progress, Cockpit from Ant-Man and Lego Movie 2 shall be up soon! Part 41823 Fence 3 x 3 x 2 - Gerald Lasser - 2019-07-16 I noticed a nice part recently, the ornamented fence got a quarter circle sibling! ... and I realized only when posting this, that it is 3 x 3 only and not 4 x 4 like the other quarter circle fences. So I played around with adding cuts into the straight piece and rotating it on the 4x4 base, which turned out pretty ok...until I, well , realized it is onyl 3x3 LDraw_41823.PNG (Size: 56.7 KB / Downloads: 45) So anybody has got this part already or has got pictures from below? May be this is a sign of a 3x3 macaroni brick coming? |
