LDD Brickset vs. LDraw Library and Parts Tracker - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: LDD Brickset vs. LDraw Library and Parts Tracker (/thread-9727.html) |
LDD Brickset 1564.1 vs. LDraw Library 2014-01 and Parts Tracker - Rolf Osterthun - 2014-10-15 Hey, the website is updated. You can have a look at the new parts (difference to Brickset 1392) here (one is an assembly). Rolf Re: LDD Brickset 1564.1 vs. LDraw Library 2014-01 and Parts Tracker - Philippe Hurbain - 2014-10-16 Quite a few interesting parts (including tumbler tire...) LDD Brickset 1564.1 vs. LDraw Library 2014-02 and Parts Tracker - Rolf Osterthun - 2015-01-02 Hey, the web-page is updated: LDD Brickset: 1564.1 LDraw Update: 2014-02 PT Server time: 2015-01-02 10:37:10 I could change the status of 82 files: 77 got official 5 are 'new' on the parts tracker Rolf Re: LDD Brickset vs. LDraw Library and Parts Tracker - Nicola - 2015-01-16 Rolf Osterthun Wrote:Since it is possible to convert LDD data to LDraw compatible data How exacly are you doing this? Re: LDD Brickset vs. LDraw Library and Parts Tracker - Rolf Osterthun - 2015-01-16 Hey Nicola, the base for the conversion was described here: http://forums.ldraw.org/showthread.php?tid=1145&pid=1145#pid1145 Is there something special you are looking for? Rolf Re: LDD Brickset vs. LDraw Library and Parts Tracker - Nicola - 2015-01-16 thanks, i was just curious.. ![]() I guess that primitives, origins etc are then manually inserted/adjusted? Re: LDD Brickset vs. LDraw Library and Parts Tracker - Max Martin Richter - 2015-01-17 Yes, that's what we usually do to get a well formed/coded part. /Max RE: LDD Brickset 2248 vs. LDraw Library 2015-02 and Parts Tracker - Rolf Osterthun - 2016-10-05 Hey, there is a new LDD update available (4.3.10). The digital-bricks.de webpage has been updated: LDD Brickset: 2248 LDraw Update: 2015-02 PT Server time: 2016-10-05 00:00:00 You can find the new parts here: http://www.digital-bricks.de/en/lddprimitives2248.php Rolf RE: LDD Brickset 2248 vs. LDraw Library 2015-02 and Parts Tracker - Philippe Hurbain - 2016-10-06 Thanks! Clearly they used part number of upper or rear mold for Wedo motors/sensors instead of whole assembly design numbers, this explains why the LDraw parts do not show in your chart. What's the status of parts whith light pink background such as 25699? RE: LDD Brickset 2248 vs. LDraw Library 2015-02 and Parts Tracker - Rolf Osterthun - 2016-10-06 (2016-10-06, 7:05)Philippe Hurbain Wrote: What's the status of parts whith light pink background such as 25699? Hey Philo, the rows that have a lighter background color represent LDD alias numbers for parts. Rolf |
