DATHeader 3.0.11.0 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: Parts Author Tools (https://forums.ldraw.org/forum-24.html) +--- Thread: DATHeader 3.0.11.0 (/thread-9450.html) |
DATHeader 3.0.11.0 - Michael Heidemann - 2013-07-31 I just released DATHeader version 3.0.11.0. This version of DATHeader accept files send by the new LDFind (version 1.3.2.0). http://ldraw.heidemann.org/index.php?page=datheader Re: DATHeader 3.0.11.0 - Michael Heidemann - 2013-09-05 Currently I am working on an update for DATHeader for the following: BUGFIX: Philo reported that BFC CERTIFY NOCLIP is not detected and corrected. NEW: The flag for alias files '=' needs to be implemented. If you know something more that needs to be fixed or should be implemented, please let me know. I know that also the low res folder is new (p\8\), but as I see this not as a common folder (only used for some special parts at present) I do not put my focus these days on this issue. Re: DATHeader 3.0.11.0 - Magnus Forsberg - 2013-09-05 I've found that it corrects soft brackets around username, but doesn't tell me about it. Isn't that a Hold vote? Re: DATHeader 3.0.11.0 - Santeri Piippo - 2013-09-05 You'll need to catch "0 BFC INVERTNEXT CLIP" as well as NOCLIP. Re: DATHeader 3.0.11.0 - Steffen - 2013-09-05 and 0 BFC CLIP INVERTNEXT ... Re: DATHeader 3.0.11.0 - Michael Heidemann - 2013-09-06 I do not know if this error should be worth a hold vote, but I feel no, because this error does not prevent the part from being showed correctly. If I submit a part to the PT I always check with DATHeader and save the file before uploading. Maybe I'll look what can be done to notify you if you only check a file. But thank you very much for mention this! Re: DATHeader 3.0.11.0 - Magnus Forsberg - 2013-09-06 To be more specific, I find the behaviour of DATHeader very strange. If a file, that has the username in soft brackets, is opened in DATHeader, the brackets have been automagically replaced with hard bracket. I want to do a review and run a scan for errors. No error is found. I close the file, of course without saving it. I then open it in LDDP or a text editor, and the soft brackets are still there. Strange. Re: DATHeader 3.0.11.0 - Michael Heidemann - 2013-09-09 The problem you describes is present. I am currently working on a solution that you will be notified if there are wrong brackets used or not. I'll keep you updated. Edit: Version 3.0.12.0 is corrected for this issue. |
