Micro ball and socket parts - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Micro ball and socket parts (/thread-9365.html) |
Re: Micro ball and socket parts - Tim Gould - 2014-01-05 How about: ball joint (8LDU) * socket joint (8LDU) * which ties it in conceptually to the larger versions, but makes it clear they are the smaller 8LDU sort. Tim PS. The builder in me loves when LEGO start a new clever part range, the part author in me less so ![]() Re: Micro ball and socket parts - Michael Heidemann - 2014-01-05 Hmmm... What about simply this: The type of connection is called joint-8 and in front whether it's male (ball) or female (socket) ball joint-8 * socket joint-8 * Re: Micro ball and socket parts - Tim Gould - 2014-01-05 I like that. What about primitive names? j8ball*.dat j8sock*.dat Tim Re: Micro ball and socket parts - Magnus Forsberg - 2014-01-05 Hi Tim, could you perhaps wait a minute. I had already all of these part prepared, and have sent them to Admin. I've made use of the new primitive cyl4sph8.dat in all of these files. 2508, 2736, 3184, 3614, 3731, 4089, 6571, 6572, 6574, 6628, 41895 I've also included one new primitive 35cyl8sph.dat That one is used in the updated version of 32186. The subfile s\32186s01 is also reworked. It would be OK with me, if they instead use the ball-primitive. Re: Micro ball and socket parts - Michael Heidemann - 2014-01-05 We are free and do not need to cut it this way i think. joint-8-balla.dat - Ball Joint-8 with Straight Bar joint-8-ballb.dat - Ball Joint-8 with Straight Bar with groove (not sure how to describe the difference) joint-8-socketa.dat - Socket Joint-8 with 4 clamps type 1 (not sure how to describe the difference) joint-8-socketb.dat - Socket Joint-8 with 4 clamps type 2 (not sure how to describe the difference) joint-8-socketc.dat - Socket Joint-8 with 2 clamps (not sure how to describe the difference) I hope I catched all possibilities ![]() Re: Micro ball and socket parts - Michael Heidemann - 2014-01-05 That sounds good ![]() Re: Micro ball and socket parts - Michael Heidemann - 2014-01-05 I just asked LDFind for the word Towball and I got a list with 28 parts, where 1 of those are only listed because of the keywords: Technic Liftarm 2 x 7 with 2 Ball Joints Name: 32173.dat All other parts are related to this kind of connection and needs to be considered. Re: Micro ball and socket parts - Tim Gould - 2014-01-05 Hi Michael, We definitely need to specify with or without friction in the socket parts. The new type (pictured in this thread) serve a very different purpose to the old type. e.g. joint-8-balla.dat - Ball Joint-8 with Straight Bar -- e.g. old parts joint-8-ballb.dat - Ball Joint-8 with Straight Bar with groove -- e.g. new parts joint-8-socket-freea.dat - Free Socket Joint-8 Round -- e.g. 3183.dat joint-8-socket-freeb.dat - Free Socket Joint-8 Square-- e.g. 98263.dat joint-8-socket-frica.dat - Friction Socket Joint-8 -- e.g. new parts If another new type comes along we add it to the free or friction lists. Tim Re: Micro ball and socket parts - Tim Gould - 2014-01-05 Was 8 hours enough? ![]() I will start working on the new parts today as it more important to get them released than to get the old parts renamed. Tim [IMPORTANT EXAMPLE NAMES] Re: Micro ball and socket parts - Tim Gould - 2014-01-05 14419.dat : "Plate 2 x 1 with Socket Joint-8 with Friction and Ball Joint-8" 63082.dat: "Plate 2 x 2 with Socket Joint-8 Square" note that part 14419 spells out "with Friction" as this is very important. |
