[Complete] 2868b Electric, Train Speed Regulator 9V - Printable Version
+--- Thread: [Complete] 2868b Electric, Train Speed Regulator 9V (/thread-8917.html)
2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-04-15
Please make 2868b Electric, Train Speed Regulator 9V
http://www.bricklink.com/catalogItem.asp?P=2868b
Please, Someone make this part.
Thanks
Re: 2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-07-12
Any Comments ??
Re: 2868b Electric, Train Speed Regulator 9V - Max Martin Richter - 2013-07-12
So many Parts on my todo list. I can only add this one...
I opened one my parts... seems to be not very complex. but creation needs time.
Re: 2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-07-17
Hi Max
Ok Thanks for the reply.
I hope you will get arround to it soon :-D
Og ja, jeg er også vild med Lego :-)
/Knud
Re: 2868b Electric, Train Speed Regulator 9V - Max Martin Richter - 2013-07-17
Please note that I have to write a test in University next Wednesday. So it will take some more time...
Re: 2868b Electric, Train Speed Regulator 9V - Short Update - Max Martin Richter - 2013-07-29
Hej,
just a short update with a little teaser:
I finished the black cover tonight.
Files with sXX.dat must copied to the s-folder. 2869.dat is the cover itself.
I will try to complete the yellow controller in the next days.
Re: 2868b Electric, Train Speed Regulator 9V - Max Martin Richter - 2013-08-03
Argh, I deleted a wrong file without backup :-(
Now I have to write the work of one day again.
So please be patient...I will do the underside now.
Update: WIP 2868b Electric, Train Speed Regulator 9V - Max Martin Richter - 2013-08-18
Just a view lines from my side. I'm working on the grey underside since a couple of days but I don't get it to the right dimension...
I think, I have to try it again and again Undecided
Ok, this part is almost finished. Only the holders for the circuit plates a are missing. But while getting these measures I found out, that I did some mistakes on the black part.
I hope, that I will finish the hole part this weekend... (Only a circuit plate dummy and some cosmetics must be done)
Update: I forgot the screws. But this shouldn't be so hard. - The part is almost ready for the wild.
Re: Update: WIP 2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-08-19
Hi Max
Thanks for the great work.
I look forward to seeing the finished result :-)
Kind Regards
Knud
Re: 2868b Electric, Train Speed Regulator 9V - Max Martin Richter - 2013-09-02
The part is ready and will be uploaded in few hours... is uploaded now.
[Image: 2868c01.png]
I haven't thought that this part is so complex. A lot of calculations had been done by drawing this part in AutoCad :-)
Only the yellow 2 x 2 connector needs to be reworked. I'll do this soon.
(I'll edit this post, when the part is uploaded)
Re: 2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-09-04
Hi Max
I will be looking forward to implementing this part in my instructions..
Kind Regards
Knud
Re: 2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-09-05
Hi Again Max
I tried yesterday to download the parts at ldraw.org and when i import it into mlcad the result looks nothin like the picture you inserted above.
I downloaded and added the following files to the parts folder:
2868c01.dat
2868.dat
2868.dat
2870.dat
5306.dat
u9266.dat
u9267.dat
u9268.dat
Here is what i see in mlcad:
http://www.snakebyte.dk/lego/2868c01.jpg
What am i missing ??
Kind Regards
Knud
Re: 2868b Electric, Train Speed Regulator 9V - Max Martin Richter - 2013-09-05
Oh, you are missing all the subfiles and primitives. You can see the referenced parts, when you watch the details of the parents on the Parts Tracker. So you have to download them manually.
OR
You can open the 2868c01 in LDView. AFAIK it should download all missing parts automatically in your unofficial parts folder (I hope you have such a folder).
Last option:
I could make you a bundle with all these files and upload them here in the forum.
Hi Max
i dont understand that you say i am missing sub parts. All the files you reference at ldraw i have downloaded and added to them to the unofficial parts folder.
i assume that the subparts should be in the same folder as 2868c01 and not in the s-subfolder ??
maybe it would be a good idea if you would upload a file :-)
Kind Regards
Knud
Hej Knud,
well all referenced parts have references to other parts inside. That's why some subparts are missing.
I have prepared a zip file, but it's not allowed to upload zip files here. So I have extended the file name with .txt . If you rename the uploaded folder back to .zip only by removing the .txt extension you should be able to see it's content. Just copy all files in the corresponding folder on your harddisk.
PS.: I hope, I have not forgotten any files ;-)
Hi Max
Thanks, that helped but..
as you can see here it looks as if one of the parts is turned the wrong way ?? :
http://www.snakebyte.dk/lego/2868C01_2.jpg
I hope you can help with this..
Kind Regards
Knud
Hej Knud,
oh...Somehow I mixed the parts of my Pre Upload and Uploaded folder together.
I attached the right file (at least I hope, it is the correct one.)
Just put it into the unofficial/parts folder.
Re: 2868b Electric, Train Speed Regulator 9V - Eric Albrecht - 2013-09-05
Thanks so much for completing this part. I have been waiting for it for a long time specifically for this V-8 model.
[Image: 8-render.jpg]
Re: 2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-09-06
Hi Max
Now its perfect - Thanks for the help :-)
Kind regards
Knud
Hi Erik
Are you also making an instruction for this model ??
This is the only part i need to finish mine :-)
What tool did you use for this render - it looks great :-)
Kind Regards
Knud
Re: 2868b Electric, Train Speed Regulator 9V - Steffen - 2013-09-06
I would love to see the MPD or LDR file for this, would you mind to upload it here?
Re: 2868b Electric, Train Speed Regulator 9V - Knud Ahrnell Albrechtsen - 2013-12-12
Hi Steffen
I have now finished the instructions for the V8 Engine.
If you still are interrested, you can see it here:
http://www.snakebyte.dk/lego/instructions/technic/robotic_arm/index.php
Kind Regards
Knud
Re: V8 Engine - Steffen - 2013-12-12
hmm. your instruction pdf on every page shows that it has been made by you, with a prominent logo,
but you don't mention the use of our parts library anywhere.
I know that that's not mandatory, but I feel the library a little underrepresented Sad
Re: V8 Engine - Knud Ahrnell Albrechtsen - 2013-12-12
Hi Steffen
I am not sure what you mean?
Do you want me to write that i have used MLCAD/LDRAW to make the instructions?
Kind Regards
Knud
Re: V8 Engine - Max Martin Richter - 2013-12-12
A line like "Created by using the LDraw Library of Parts" or something else would indeed be great :-)
Hilsen!
Hi
Ok, I will look into this later.
Kind Regards
Knud
