LSynth : "Add comand..." not activated... : fixed - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: LSynth : "Add comand..." not activated... : fixed (/thread-871.html) |
LSynth : "Add comand..." not activated... : fixed - Fabrice Vion - 2011-09-12 Hi, I have a problem to use LSynth in ML Cad. The command "Add command..." (in Extras/LSynth) isn't activated (it's grey and not black). It used to work fine, so I don't understand which condition is missing today. Could somebody help me ? Thanks in advance, Fabrice Re: LSynth : "Add comand..." not activated... - Jason Smith - 2011-09-13 Hello Fabrice, Did you change any of your folders around? Check your MLCad.ini file and make sure the path to LSynth is set correctly, maybe something changed. Re: LSynth : "Add comand..." not activated... - Fabrice Vion - 2011-09-13 Hello, I checked all the files and programs and I discovered that I had two MLCad versions installed. The oldest which wasn't linked to LSynth was the default one. I desintalled it and now use the most recent version and it works fine. Thanks a lot Jason. Fabrice Re: LSynth : "Add comand..." not activated... - Willy Tschager - 2011-09-13 Hi Fabrice, same story as for Jason. It would be nice if you could sum up the above in a paragraph I can add to my troubleshooting page: http://www.holly-wood.it/lsynth/troubleshooting-en.html Thx, in advanced, w. Re: LSynth : "Add comand..." not activated... - Fabrice Vion - 2011-09-13 Hi Willy, I put a screen shot of the problem here : http://dl.free.fr/mpvwUkDB6 you must click on "Télécharger ce fichier" to download the jpg screen shot (37,4 ko). I had two versions of ML Cad installed on my computer. Only the most recent one was configured to work with LSynth, but the default version (used when I double click on a .ldr file) was the oldest one. So I couldn't access LSynth fonctionalities. I remove this old version to avoid to be confused. It now works fine. Re: LSynth : "Add comand..." not activated... - Fabrice Vion - 2011-11-01 For people who could have the same problem than I Had, here is the explalation and solution : In fact Ldraw was installed to time on my computer. Lsynth was installed was only installed in one Ldraw file, but the other was the default program. So when I opend a .ldr file, the default Ldraw was opened and I couldn't use Lsynth. I uninstalled the default program and declared the other one as the default Ldraw. Thanks a lot to people who helped me to fix. Fabrice |
