Some missing part - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Some missing part (/thread-8673.html) |
Some missing part - Calogero Lombo - 2013-03-18 Hi, first thank you for your work. After a lot of years of utilization, I developed the dream of to do as many as possible of official sets with the correct parts. I know that this dream is quite impossible and that there is similar part that can be used, but I want to try to achieve my dream. With humility, I ask if there is someone with spare time to create some of the following parts to help me (I have tried with a conversion from LDD but the result is visually good, but in reality I do not succeed to optimize the parts so to use them properly). Best regard and still many thanks for the part made in this year CL The list: 6014b Wheel 11.5mm D. x 12mm, Hole Notched for Wheels Holder Pin (the actual version is very different) 58088 Wheel Cover 7 Spoke with Axle Hole (for the set 8145 Ferrari 599 GTB Fiorano) 60032 Window 1 x 2 x 2 Plane, Single Hole Top and Bottom for Glass (for set 4997 Transport Ferry) 30625 Hinge Panel 1 x 4 x 3 2/3 with 6 holes, 2 studs on top, Locking 2 Fingers 3245c Brick 1 x 2 x 2 with Inside Stud Holder Re: Some missing part - Michael Heidemann - 2013-03-18 From where do you have those numbers? So we are able to identify correct what you need. I looked for example for the last part with the number you gave on Bricklink (http://www.bricklink.com/catalogItem.asp?P=3245c) and the part looks very much like our 3245b.dat. Re: Some missing part - Calogero Lombo - 2013-03-20 Yes, the 2 parts are very similar to each other. Instead there is a greater diversity between the 6014b and 6014 currently present: the form of the attack of the pin (see the images in http://www.bricklink.com/catalogItem.asp?P=6014b) and also there is a slot on the side (see the big picture in http://www.bricklink.com/catalogItem.asp?P=6014a showing the lateral part of the a-version equal to that of the version b) Even for the 60032 there is a diversity towards the 2377 such that the glass to be used in the two parts are different from each other (http://www.bricklink.com/catalogItem.asp?P=60032) For the 30625 and 58088 I don't know a similar part to use |
