Light & Sound 1x2 brick with light - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Light & Sound 1x2 brick with light (/thread-7166.html) |
Light & Sound 1x2 brick with light - Ignacio Fernandez Galvan - 2012-12-06 In another post, Philippe Hurbain informed me that the current 4771 (L&S 1x4 brick) part is actually made of 73664, a composite of 4771, 4772 and 4769. I've uploaded all of these to the PT. I have also done the corresponding parts for the 1x2 brick (current 4767), but I don't know what should be the corresponding part numbers for the bottom part and the shortcut. Can anybody tell me? (I tried looking in the physical piece, but I only found the 4767 code in the top part.) Re: Light & Sound 1x2 brick with light - Philippe Hurbain - 2012-12-06 Top is indeed 4767. Bottom is... (guess what...) 4768!. Bulb protection is 4769 as in 1x4. Assembly is 73666. Thanks for cleaning these parts! Re: Light & Sound 1x2 brick with light - Ignacio Fernandez Galvan - 2012-12-06 Thank you! They're uploaded now
