[LDPartEditor] First Alpha Version News (until 2014-09-19) - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: Parts Author Tools (https://forums.ldraw.org/forum-24.html) +--- Thread: [LDPartEditor] First Alpha Version News (until 2014-09-19) (/thread-7056.html) |
[LDPartEditor] First Example (Manipulator) - Nils Schmidt - 2014-07-11 LDPartEditor's manipulator will support
![]() [LDPartEditor] Colour Manipulation - Nils Schmidt - 2014-07-15 It's now possible to manipulate the colours. ![]() [LDPartEditor] More Manipulator Features - Nils Schmidt - 2014-07-23 I implemented a bunch of new features for the 3D manipulator in this week and the week before. You can now...
PS: I will change the icon design and the icon order from time to time to better clarify the unique features which are kept behind these buttons and improve the usablility. By now, it's a little bit cryptic ![]() ![]() Re: [LDPartEditor] More Manipulator Features - Philippe Hurbain - 2014-07-24 :-D :-D :-D [LDPartEditor] Texture Mapping: TEXMAP PLANAR - Nils Schmidt - 2014-07-27 LDPartEditor will support the full "Language Extension for Texture Mapping". Here are the first screenshots showing "!TEXMAP PLANAR" doing its magic ![]() ..early version of the TEXMAP parser (you can see tiny white edges in the texture).. ![]() ..early version with transparency.. ![]() ..now with improved image quality... ![]() ![]() ![]() [LDPartEditor] TEXMAP PLANAR / CYLINDRICAL / SPHERICAL (I need help) - Nils Schmidt - 2014-07-27 Code: 0 !TEXMAP START PLANAR 0 0 0 10 0 0 0 10 0 checker.png I don't know if it is displayed correctly. I need more information for the SPHERICAL and CYLINDRICAL projection methods since they are difficult to understand. I simply don't know what I should expect when I do a "SPHERICAL" or "CYLINDRICAL" mapping with !TEXMAP... https://lh3.googleusercontent.com/-_lcQ5K8qEEY/U_JkurmcCII/AAAAAAAAAEE/bWDYZhSzeYo/w605-h457-no/TEXMAP_ALL.png Re: [LDPartEditor] TEXMAP PLANAR / CYLINDRICAL / SPHERICAL (I need help) - Roland Melkert - 2014-07-27 Purely from a 'feeling' kind of view, I don't think the cylinder and sphere are correct. I have yet to implement/study the texmap extention for use in my LDCad but, I would expect the shapes to retain the checker pattern (but curved) in your example. Re: [LDPartEditor] TEXMAP PLANAR / CYLINDRICAL / SPHERICAL (I need help) - Travis Cobbs - 2014-07-28 For cylindrical, definitely if you have the settings right to match the cylinder that you're mapping onto, the checkerboard should indeed wrap around the cylinder and look even. For a unit half-cylinder centered with its bottom at 0, 0, 0, I believe the parameters would be 0 0 0 0 -1 0 0 0 1 180. (I color coded the numbers to make it easier to read.) With those settings, the left edge of the texture would map to left edge of the half-cylinder, the right edge of the texture would map to the right edge of the half-cylinder, and the middle bottom of the texture would be at coordinates 0, 0, 1, which would be the bottom center of the half-cylinder's surface. For spherical, I'm not completely sure what it's supposed to look like, but if you used the same texture map for all three shapes, I don't think what you have is right. However, I believe for a unit sphere at the origin with texmap params 0 0 0 0 0 1 1 0 1 180 180, the center of the texture would map to the point at 0 0 1, and the texture near that point would look fairly non-warped. The checkerboard would get progressively more warped as you move further from that point. The centers of each of the four edges of the texture would map to the edge of the half-sphere, and everything outside a circle inscribed in the texture's square would be invisible (out of bounds). [LDPartEditor] TEXMAP CYLINDRICAL is now working. - Nils Schmidt - 2014-07-28 Thanks Travis. I finally managed to find a solution for the cylindrical projection. Code: 0 // btw: I changed the unit to degrees instead of radians ![]() Re: [LDPartEditor] TEXMAP CYLINDRICAL is now working. - Roland Melkert - 2014-07-28 Very nice, I would expect the spherical one to look like the right green/yellow one on this page https://en.wikipedia.org/wiki/UV_mapping |
